Thread Closed
simplifying regular expression?
Share Thread
Jan20-07, 05:52 PM   #1
Does anyone know if this regular expression can be simplified?
(a*bc*bc*|c*)*b
I tried (a|b|c)*b, but it's not correct.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jan20-07, 06:57 PM   #2
Well in that group you have the same suffix on both words, so you can factor it out (1). Then notice that the content in that group might be empty which is a problem because it will run away on failure, so we must disallow that that empty case. We can do that with a branch (2).
#0: (a*bc*bc*|c*)*b
#1: ((a*bc*b)?c*)*b
#2: ((a*bc*b)c*|c+)*b
You can reduce the number of operators by one by factoring out c*:
#3: ((a*bc*b|c)c*)*b
Now you have a problem with the c's which is difficult to explain. The clash is between the last c* and the )* (it's because that group can simplify to c+ in certain cases). The way around that is to force that c* to group atomically so that it won't backtrack.
#4: ((a*bc*b|c)c*+)*b
OR ((a*bc*b|c)(?>c*))*b
Now that should work well enough but to be pedantic those first 2 *'s don't need to backtrack:
#5: ((a*+bc*+b|c)c*+)*b
Unfortunately that last * does need to be able to backtrack because there might be an even number of b's being matched against and it would fail in that case if that group was atomic.
Needless to say, regexes are difficult. I learned them from the PHP manual 'PCRE' section. You can find it online.
Jan20-07, 07:03 PM   #3
Hmm, so it cannot be simplified to something really short ie. (a|b|c)*b (which is wrong) as it seems.
Thanks.
Thread Closed
Similar discussions for: simplifying regular expression?
Thread Forum Replies
Simplifying an expression Precalculus Mathematics Homework 2
regular and non-regular magic squares Calculus & Beyond Homework 0
Simplifying an expression Introductory Physics Homework 2
Volumes of Regular Icosahedron and Regular Tetrahedron General Math 20
