String tension, is this the correct formula?
The correct formula for string tension is T = 1/(2πα'), where α' represents alpha prime. The variable p in the initial formula discussed is identified as π (pi), which is approximately 3.14. This formula is applicable to closed strings, and variations in sources may lead to differences by a factor of 2, which should not be a cause for concern.
  • Understanding of string theory concepts
  • Familiarity with the mathematical constant π (pi)
  • Knowledge of alpha prime (α') in string theory
  • Basic grasp of tension in physical systems
  • Research the implications of alpha prime (α') in string theory
  • Explore the role of tension in closed strings
  • Study the mathematical derivation of string tension formulas
  • Investigate variations in string theory literature regarding tension calculations
Physicists, students of string theory, and anyone interested in the mathematical foundations of string tension in theoretical physics.
ant0
I read in a book that tension = 1/(pa'), where a' = alpha prime.
Is this the correct formula for string tension and if so what is p?
in my book, it is
[tex]T=\frac{1}{2\pi\alpha'}[/tex]
[itex]\pi[/itex] is the ratio of the circumference of a circle to its diameter, approximately 3.14. and if your source differs by a factor of 2 from mine, i wouldn't worry about it.
ah, p must be pi then, would that make sense for a closed string then?
  • · Replies 18 ·
  • · Replies 33 ·
10K
