What Was the Launch Angle of the Projectile?
The problem involves determining the launch angle of a projectile given that its speed at half of its maximum height is three-quarters of its initial speed. The context is rooted in kinematics, focusing on the motion of projectiles and the relationships between their velocity components.
  • Participants discuss the components of projectile motion, particularly the distinction between the x and y components of velocity. There are inquiries about the meaning of "speed of a projectile" and how to denote it. Some participants suggest using energy conservation principles, while others emphasize kinematic equations. Questions arise regarding how to express the y-component of velocity in terms of the initial speed.
There is an ongoing exploration of different approaches to the problem, including kinematic equations and energy considerations. Some participants have provided insights and hints, while others express uncertainty about how to proceed. The discussion reflects a collaborative effort to clarify concepts and reasoning without reaching a definitive conclusion.
Participants note that the problem is situated within basic kinematics, and there is a mention of the absence of air resistance in projectile motion. The discussion also highlights the challenge of working with multiple unknowns in the equations presented.
un0rth0d0x
At .5 of its maximum height, the speed of a projectile is .75 of its initial speed. What was its launch angle?
(1)V1y = V0y - gt
(2)y1-y0 = V0yt - .5gt^2
The part that really bothers me is the second part of the first statement: "the speed of a projectile ..." What is the speed of a projectile? What do i denote that as? V?...
So far I've gotten the following:
initial velocity y-component:
knowing: V1y = 0 (at max height)
V1y = V0y - gt
Voy = gt
substitute V0y into equation (2) gives max height:
y=.5gt^2
Any assistance would be most appreciated.
Thanks!
Hi un0rth0d0x,
welcome to PF. Hope we can help you here with you physics questions.
Since the projectile is subject to just a conservative force this problem can be solved using energy considerations.
Have you done the relevant theory concerning energy conservation yet?
Unfortunately I have not... This problem is sectioned in basic kinematics... So I'm totally oblivious to energy conservation.
Sorry
The "speed" of the projectile [tex]v[/tex] has two components [tex]v_x,\ v_y[/tex] of which the y-component changes and the x-components stays the same throughout the trajectory.
andrevdh: just out of interest, how would you sort this out using energy considerations alone? I have had a quick bash, and can't see an obvious way to do it...
anyway, I would approach this problem with kinematic equations of motion.
In situations like this, remember that if you're given letters or proportions then you effectively "know" the value, don't get scared just because there isn't an actual number. It seems that's exactly what you've done, so good on you.
Second, you should realize that any projectile motion problems involving no air resistance are simply parabolic geometry problems in disguise
third, always but always draw a diagram! it helps to visualise the problem.
Now, if you have the x components and the y components, what shape can you make with them?
As we know the speed of a projectile changes during its motion. The problem therefore says that the speed [tex]v[/tex] (the x- and y- components combined) at half maximum height will be 3/4 of the launching speed [tex]v_0[/tex].
Remember that the x - velocity component can be written as
[tex]v_x = v_o \cos(\theta _o)[/tex]
while we need to solve for
[tex]\theta _o[/tex]
energy at bottom:
[tex]0.5mv_o ^2[/tex]
energy in middle:
[tex]\frac{9}{32}mv_o ^2 + 0.5mgh[/tex]
energy at top:
[tex]0.5mv_o ^2 {cos}^2(\theta_o) + mgh[/tex]
The problems says that the speed at half the maximum height is 3/4 of the initial speed. Since the speed of the projectile is the combination of both speed components we can say that
[tex]v^2 = v_y ^2 + v_x ^2[/tex]
at half the maximum height this therefore becomes
[tex](\frac{3v_o}{4})^2 = v_y ^2 + v_o ^2 {cos}^2(\theta_o)[/tex]
Can you solve it now?
Thanks for your help!
-d0x
Sorry to bump such an old thread.
I am trying to figure out this exact question, and I see what steps they have taken in this thread, but I don't understand where to go from there. Any additional assistance would be appreciated, I am just plain stuck on this.
Thanks!
[tex] (\frac{3v_o}{4})^2 = v_y ^2 + v_o ^2 {cos}^2(\theta_o)[/tex]
Now we have one equation with two unknowns, so try to express vy in terms of v0. Hint: use vf^2 - vi^2 = 2ad. Twice.
10K
28K
