How Do You Solve These Calculus Differentiation Problems?
  • Thread starter Thread starter mcintyre_ie
    Differentiation
The discussion revolves around differentiation problems in calculus, specifically focusing on a cubic function and a complex quotient involving exponential and trigonometric functions. Participants are exploring the conditions for local turning points and the application of logarithmic differentiation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to derive a condition for a cubic function to have one local turning point, leading to a discussion about the quadratic formula and the implications of repeated roots. Some participants question the use of specific formulas and the notation used for coefficients. For the second problem, there is uncertainty about the correct interpretation of the function and the application of logarithmic differentiation.
Participants are actively engaging with the problems, offering insights and clarifications. There is a mix of interpretations regarding the notation and methods, particularly in the second problem. Some guidance has been provided on using logarithms for differentiation, but no consensus has been reached on the best approach.
There is mention of potential confusion due to the use of similar letters for different coefficients in the cubic function. Additionally, the original poster acknowledges a typographical error in the expression for the second problem, which has led to further clarification requests.
mcintyre_ie
Hey
I'd really appreciate some help with the following differntiation problems:
(i) Let f(x) = ax^3 + bx^2 + cx +d, where a, b, c, d are å R.
Given that f(x) has only one local turning point, show that:
b^2 = 3ac
Hence, find the coordinates of the local turning point.
Here are my workings for the first part:
b^2 - 4ac = 0 (from formula)
4b^2 - 4(3a)(c) = 0
4b^2 = 12ac
b^2 = 3ac
For the second part, finding the coordinates, I am not sure what i should do, any advice?
(ii) Using logarithms, or otherwise, differentiate:
y=(e^x^2\sqrt{SinX})/(2x + 1)^3
Ok, so I've been trying to do this, but I'm not sure where the logarithms part comes into it, or where to start, maybe a quotient rule?
Any help is appreciated.
Whaa? Where did you get this formula from?
I would do it by differentiating:
f'(x) = 3ax^2 + 2bx + c = 0
This gives one turning point, given repeated roots in x.
ie. (2b)^2 - 4*3*a*x = 0
This can be solved easily.
Coordinates? Quadratic formulae, again.
x = -2b/6a (since the square root bit equals 0 for repeated roots)
Substitute, and viola!
That does look nasty, doesn't it?
Can you clarify with brackets etc what (e^x^2\sqrt{SinX}) is? Do you mean:
e^((x^2)/(sqrt(sinx)))?
As for logs, perhaps you are meant to log both sides, and differentiate implicitly?
"Here are my workings for the first part:
b^2 - 4ac = 0 (from formula)"
My first reaction was the same as FZ+: "where did you get that formula"? Then I realized that you are using the same letters to mean different things.
Given a cubic ax3+ bx2+ cx+ d, a turning point can only occur where the derivative: 3ax2+ 2bx+ c= 0
That can be solved using the quadratic formula and, in order that there be exactly 1 turning point, there must be exactly one solution so "b2- 4ac= 0" where a,b,c are now the coefficients of ax2+ bx+ c. Putting in the values 3a and 2b for "a","b" gives you the rest:
"4b^2 - 4(3a)(c) = 0
4b^2 = 12ac
b^2 = 3ac"
BAD IDEA! Never use the same letters to represent different things! Or at least tell us you are doing that!
As for finding the turning point: 3ax2+ 2bx+ c= 0 and
b2= 3ac. Okay, then, again, from the quadratic formula,
since the discriminant is 0 x= -2b/(6a). You can plug that into the original cubic to find y (exactly what FZ+ suggested)
Like FZ+, I have no idea what "y=(e^x^2\sqrt{SinX})/(2x + 1)^3" is, in part because of that "\". My guess, like his, is that you meant
y=(e^{x^(x^2/sqrt(sin(x)))})/(2x+1)^3.
log(y)= x^(x^(2/sqrt(sin(x)))))-3log(2x+1) which should be easier to differentiate.
Ok, thanks for the help with the first part. I should probably have explained that the formula was taken from the quadratic formula x = [-b +/- squrt(b^2-4ac)]/2a, using the b^2-4ac = 0 to show that it has one real root.
I think the reason the question was asked using a,b,c,d was to confuse people trying to do it.
As for the log question, i didnt make a great job of typing it out, so ill try again:
Y = [{e^(x^2)}.sqrt{SinX}]/[(2x + 1)^3
Y = e to the power of x squared by the square root of sinX, divided by (2x + 1) to be cubed.
Thanks again for the help.
Any ideas on solving the second problem?
is it
[tex]y=\frac{e^{x^2} \sqrt{\sin x}}{(2x+1)^3}[/tex]
Yeah, that's it, my latex skills arent really up to scratch yet. Thanks, any clues on solving?
take log u will get
[tex]logy= x^2+\frac{log sinx}{2} - 3log(2x+3)[/tex]
and now differentiate u will get the desired result
  • · Replies 19 ·
