| New Reply |
Derivation of the Equation for Relativistic Mass |
Share Thread | Thread Tools |
| Feb1-07, 01:55 AM | #35 |
| Feb1-07, 02:28 AM | #36 |
| Feb1-07, 03:03 AM | #37 |
Mentor
| Feb1-07, 04:32 AM | #38 |
For more details please have a critical look at arXiv.org > physics > physics/0605203 Date: Tue, 23 May 2006 22:28:50 GMT (259kb) Relativistic dynamics without conservation laws Subj-class: Physics Education We show that relativistic dynamics can be approached without using conservation laws (conservation of momentum, of energy and of the centre of mass). Our approach avoids collisions that are not easy to teach without mnemonic aids. The derivations are based on the principle of relativity and on its direct consequence, the addition law of relativistic velocities. Full-text: PDF only I would highly appreciate your experience with it. |
| Feb1-07, 10:34 AM | #39 |
L(u)*L(v)=L(w) where w=(u+v)/(1+uv/c^2)) where L(v)=gamma(v)*|1............-v| ...............................|-v/c^2......1| Try it, you might even be able to calculate it all by yourself. |
| Feb1-07, 10:48 AM | #40 |
You use a hypothetical collision experiment You use the conservation of momentum equation as "seen" from two different frames (you call them I and I', right?). This is the formalism employed by Tolman about 100 years ago. |
| Feb1-07, 01:45 PM | #41 |
Mentor
| Feb1-07, 10:04 PM | #42 |
| Feb1-07, 10:09 PM | #43 |
| Feb7-07, 11:50 AM | #44 |
It's been a while, I left this thread because of the now fortunately deleted bickering. However, having once again picked up this subject, no matter how useless, I've stumbled upon a problem. I refer to this post:
http://www.physicsforums.com/showpos...3&postcount=21 It states: [tex]m(u_1)u_1+m(u_2)u_2 = (m(u_1)+m(u_2))V[/tex] However, since after the collision the speeds are no longer [tex]u_1[/tex] and [tex]u_1[/tex], how can you say that the relativistic mass of the "new" object is simply [tex]m(u_1)+m(u_2)[/tex]? |
| Feb8-07, 11:37 AM | #45 |
Though he only had time for a quick glance, my physics teacher agreed that this looked incorrect.
He also suggested I should use the following equation to derive the equation for relativistic mass (I was too lazy to LaTeX, so here's a link): http://hyperphysics.phy-astr.gsu.edu...grel/emcpc.gif I'm not sure how to go about that, though. If anyone has any comment on why that which I think to be false is true or any suggestion on how to go about this using the referred equation, I'd much appreciate it. |
| Feb8-07, 02:23 PM | #46 |
[tex]m(u_1)u_1+m(u_2)u_2 = (m(0)+m(0))V[/tex] However,I think that Tolman must have assumed that mass cannot vary non-continously (from [tex]m_1(u_1)[/tex] to [tex]m_1(0)[/tex]), thus justifying his use of : [tex]m(u_1)u_1+m(u_2)u_2 = (m(u_1)+m(u_2))V[/tex] Granted, this is a very weak argument, so the best thing is to dump the blasted "relativistic mass" altogether, as I mentioned in the opening statement. The whole darned thing was introduced in order to reconcile the relativistic momentum/energy: [tex]p=\gamma m(0)v[/tex] (1) [tex]E=\gamma m(0)c^2[/tex] with the Newtonian counterpart: [tex]p=mv[/tex] (2) So the best thing is to tell your teacher that your proof is you grouped together [tex]\gamma[/tex] and proper mass m(0) into [tex]\gamma m(0)[/tex] and you assigned that quantity to m |
| Feb8-07, 04:01 PM | #47 |
| Feb8-07, 04:17 PM | #48 |
[tex]m_1(u_1)u_1+m_2(u_2)u_2=(m_1(V)+m_2(V))V[/tex] Doesn't change anything, the derivation is still flawed. [tex]m_1u_1+m_2u_2=(m_1+m_2)V[/tex] So, Tolman must be assuming [tex]m_1(u_1)[/tex] before and after the collision in his formula. Otherwise, the derivation falls apart. Conclusion: use the derivation based on relativistic momentum I gave you twice. |
| Feb8-07, 04:34 PM | #49 |
| Feb8-07, 04:35 PM | #50 |
Look at the bottom. |
| Feb8-07, 09:55 PM | #51 |
Try starting with:
ds^2 = (cdt)^2 - dx^2 Divide through by dt^2 and rearrange: c^2 = v^2 + (ds/dt)^2 Multiply by m^2 to get p^2: (E/c)^2 = p^2 + (m*ds/dt)^2 Make the last term a constant: m*ds/dt = Eo/c And arrive at: mc = Eo*dt/ds Which from the 2nd eqn above is: mc^2 = Eo/[1-(v/c)^2] = E The Lorentz transformations come from the invariance of ds. The mass behaves just so that the rest energy is invariant. |
| New Reply |
| Thread Tools | |
Similar Threads for: Derivation of the Equation for Relativistic Mass
| Relativistic Doppler Shift Equation - Derivation | Introductory Physics Homework | 7 | ||
| Non-relativistic derivation of Schwarzschild's equation | Special & General Relativity | 8 | ||
| Derivation of the Equation for Relativistic Momentum | Special & General Relativity | 8 | ||
| Derivation of equation for mass on pulley and displacement | Introductory Physics Homework | 3 | ||
| Mass As Gravitational Charge & Derivation Of Geodesic Equation Of Motion | General Physics | 0 | ||
