Step Up Voltage from Disposable Camera Flash
  • Thread starter Thread starter Muteibanez
The discussion centers on stepping up voltage using the circuit from a disposable camera flash. Participants clarify that the coils in the circuit are not merely coiled wires but are part of a transformer consisting of a primary and secondary coil wound on a common core. The transformation of voltage and current is explained using the relationship of power (watts) and the concept of a transformer ratio. A simple solution suggested is using a 555 timer and a transistor to create an AC-like signal from a DC battery, which can effectively step up voltage.
  • Understanding of transformer operation and coil configuration
  • Basic knowledge of AC and DC electrical concepts
  • Familiarity with 555 timer circuits
  • Experience with basic electronic components like capacitors and transistors
  • Research transformer design and voltage transformation principles
  • Learn about 555 timer applications in creating oscillating signals
  • Explore strobe circuit kits and their components for practical implementation
  • Investigate safety precautions when working with high voltage circuits
Electronics enthusiasts, hobbyists working with DIY circuits, and anyone interested in understanding voltage transformation in simple electrical systems.
Muteibanez
http://science.howstuffworks.com/camera-flash2.htm
check out the schematics for a basic flash of a disposable camera, i am new to this part of physics, i just learned about DC. Anyway can someone give me #'s that might work with this circuit to achieve a step up voltage? Also are the "coil's" just coiled wires?
...Anyway can someone give me #'s that might work with this circuit to achieve a step up voltage? Also are the "coil's" just coiled wires?
It's a simple circuit but instead of building one, I would just buy a throw-away camera and remove the circuit.
Those aren't mere coils. That's two separate coils that are wound on one common core, thus creating a transformer.
When you feed AC into a transformer, the one coil (called the primary) turns the electricity into magenetics which flows along the core to the other coil (called the secondary) where it comes back out as electricity. However, during that transformation you can change voltage and amperage much like a car transmission changes torque and rpm. The power (volts times amps = watts) stays the same excepting for losses, but you get a ratio effect. So neglecting losses, let's say you have 12V AC signal with 2A of current going into a transformer with a ratio of 2. Coming out the other side could be either 24V AC with 1A of current OR you could have 6V AC with 4A or current depending on which way you wire the transformer.
We have a DC battery, but can switch it on/off to make something that resembles AC and it works on the tranformer to step up the voltage (and stepping down current at the same time). This switching could be done with a simple 555 timer and transistor, but it doesn't sound like you're quite at that stage.
Simplist circuit would be something like a $10 strobe kit I've seen that can charge a capacitor to 120V.
Cliff
P.S. You might want to read around their site a little more too, they explain the circuit in more detail than would be feasible to type up here.
  • · Replies 25 ·
