Edge triggered JK flip flop
by Amith2006
Tags: edge, flip, flop, triggered
Amith2006
Amith2006 is offline
#1
Jan29-07, 01:11 PM
P: 424
I am unable to understand the working of a positive edge triggered JK flip flop. In the figure, there are 2 AND gates on the left (one over the other) and there are 2 NOR gates on the right (one over the other). I have used an RS flip flop to construct the JK flip flop. The inputs J and K are denoted as 2 & 5 respectively. Q is the complement of Q. The output Q is connected to input number 1 of upper AND gate and the output Q is connected to input number 6. The inputs 3 & 4 are connected to the clock pulse.
Now consider the input condition J=0, K=1 and at this point the clock pulse makes a positive transition. The explanation given in my book is as follows:
When J is low and K is high, the upper AND gate is disabled, so there is no way to set the flip flop. The only possibility is reset. When Q is high, the lower gate passes a reset pulse as soon as the next clock edge arrives. This forces Q to become low. Therefore, J=0, K=1 means that the next positive transition of the clock resets the flip flop.
The lower gate sends a reset pulse which means it sends a low voltage signal. Why does this happen? Now, the lower AND gate has 3 inputs. At the time the positive edge of clock pulse arrives, K=1. So, two of the inputs of the lower AND gate is high. Suppose at this instant, Q was high. Then three of the inputs of the lower AND gate is high, which means the output would be high .i.e. S is high. A high at any of the inputs of a NOR gate gives a low output. Hence Q is low. Now, Q is one of the inputs of the upper NOR gate. As J=0, R=0. Hence the two inputs of the upper NOR gate is low. Hence, Q=1. There is something to do with the third input(1 & 6). I think digital electronics is tough if you dont have good teacher. Someone please guide me!!!!!!!!!!!
2. Relevant equations
3. The attempt at a solution
Phys.Org News Partner Engineering news on Phys.org
PsiKick's batteryless sensors poised for coming 'Internet of things'
Researcher launches successful tech start-up to help the blind
Researchers propose network-based evaluation tool to assess relief operations feasibility
Amith2006
#2
Jan29-07, 01:16 PM
P: 424
Sorry, I forgot to attach the circuit diagram.
berkeman
berkeman is online now
#3
Jan29-07, 03:49 PM
Mentor
berkeman's Avatar
P: 39,611
Looks like you are missing a stage or two in your diagram -- maybe that's where the confusion is coming from. I went through HowStuffWorks to find a page about the JKFF for you:
http://www.play-hookey.com/digital/j...flip-flop.html
BTW, I think I'll move this to the EE forum, since it's not strictly homework, and more of a question about understanding how a general cicuit element curcuit works.
Register to reply
Related Discussions
design for jk flip flop Engineering, Comp Sci, & Technology Homework 0
Design a synchronous circuit using negative edge-triggered D Engineering, Comp Sci, & Technology Homework 1
j-k flip flop Engineering, Comp Sci, & Technology Homework 3
jk flip flop Engineering, Comp Sci, & Technology Homework 3
How many flip-flop per state? Electrical Engineering 4
