Finding Points of Inflection in Harmonic Oscillator Wave Function
The discussion focuses on applying direct differentiation to the ground state wave function of a harmonic oscillator, represented as Psi=A*e^(-sqrt(mk)x^2/(2*h_bar))*e^(-i*w*t/2). The normalization constant A is determined to be A=(m*k)^(1/8) / (2*(pi*h_bar)^(1/4)). The second derivative of Psi is computed, leading to the equation (1+0.5*x^2) * e^(-sqrt(mk)x^2/(2*h_bar)) = 0, which yields complex solutions for inflection points. The discussion emphasizes the need for careful differentiation and consistency in the application of terms.
  • Understanding of quantum mechanics, specifically harmonic oscillators
  • Familiarity with wave functions and normalization techniques
  • Proficiency in calculus, particularly differentiation
  • Knowledge of complex numbers and their implications in physical equations
  • Study the normalization of wave functions in quantum mechanics
  • Learn about the significance of inflection points in wave functions
  • Explore advanced differentiation techniques in calculus
  • Investigate the role of complex solutions in quantum mechanics
Students and professionals in physics, particularly those studying quantum mechanics, as well as educators looking to enhance their understanding of harmonic oscillators and wave function analysis.
ynuo
Apply direct differentiation to the ground state wave function for the harmonic oscillator,
Psi=A*e^(-sqrt(mk)x^2/(2*h_bar))*e^(-i*w*t/2) (unnormalized)
and show that Psi has points of inflection at the extreme positions of the particle's classical motion.
My understanding of this question is first I have to normalize the wave function to get the value of the constant A. Then I must differentiate twice and set the second derivative of the wave function to zero and solve the resulting equation. When I do that I get an equation whose solution is complex and is different than that required by the question.
Normalization:
after normalization I get A=(m*k)^1/8 / (2*(pi*h_bar)^1/4)
Differentiation:
d(Psi)/dx=A*(-sqrt(m*k) / h_bar) e^(-i*w*t/2) * x *e^(-sqrt(m*k)x^2/(2*h_bar))
d^2(Psi)/dx=A * e^(-i*w*t/2) * [(-sqrt(m*k) / h_bar) * e^(-sqrt(m*k)x^2/(2*h_bar)) + 4 * x^2 * (-sqrt(m*k) / 2*h_bar)^2 * e^(-sqrt(m*k)x^2/(2*h_bar))]
Setting d^2(Psi)/dx=0 I get:
Whose solution is: 1.414213562 i, -1.414213562 i
In the first place, neither the normalization nor the time-dependent part will have anything to do with location of the inflection points. Just drop them. You are not including them consistantly anyway. Second, in your first version of the second derivative I see a sign difference between the x^2 term and the other one. In your last form it has disappeared. Do it again. Much more carefully.
9K
