| Thread Closed |
Block on frictionless ramp |
Share Thread | Thread Tools |
| Feb4-07, 01:10 PM | #1 |
i have been having trouble with this problem...if anyone could help me as soon as possible i would really appreciate it !!!(this is due today)...thank you!!!!! The problem: A block starts at rest and slides down a frictionless track. The acceleration of gravity is 9.81m/s^2. It leaves the track horizontally, striking the ground. ![]() A. at what height above the ground is the block released? B. What is the speed of the block when it leaves the track? i solved, and the correct answer was 5.289 m/s C What is the speed of the block when it hits the ground? 2. Relevant equations 3. The attempt at a solution i solved part B, and the correct answer was 5.289 m/s 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution for B: I did -2.4m = 1/2 (-9.81m/s^2)(t)^2 and got t = .6995 V = 3.7 / .6695 =5.289 m/s |
| Feb4-07, 01:44 PM | #2 |
Mentor
What do the actual question specify? i.e. do you know the height h, or is that what you are asked to find in (A)?
For part (B), is that the correct answer given to you by a book, or is that the answer you've calculated? |
| Feb4-07, 01:49 PM | #3 |
It is an online submission thing.. you do the hw online and it says that i got B correct...you have so many guesses to get it correct...the question below is the actual question and the picture that i did was actually given...thank you for replying me!
A block starts at rest and slides down a frictionless track. The acceleration of gravity is 9.81m/s^2. It leaves the track horizontally, striking the ground. ![]() A. at what height above the ground is the block released? B. What is the speed of the block when it leaves the track? C What is the speed of the block when it hits the ground? |
| Feb4-07, 01:50 PM | #4 |
Mentor
| Feb4-07, 01:55 PM | #5 |
I solved B but i dont exactly know where to start A or C from there or how B ties in with them.
| Feb4-07, 01:57 PM | #6 |
Mentor
Ahh, ok, I didn't read the question properly!
Yes, your answer to (B) is correct. Are you having trouble with (A) or (C) or both? For (A), consider the energy of the block whilst it's on the slope. At the top it's at rest, and so has only potential energy. As it leaves, it has less potential energy, but kinetic energy. Using the principle of conservation of energy, you can find the initial potential energy, and hence h. For (C), consider the x and y components of the final velocity and use the kinematic equations. |
| Feb4-07, 02:00 PM | #7 |
Mentor
Hint: There's no friction, so mechanical energy is conserved. Consider the block's total mechanical energy just as it leaves the track, then compare that point to its starting point and landing point. What changes?
| Feb4-07, 02:17 PM | #8 |
so would i do:
KE = 1/2 mv^2 1/2 (.534)(5.289m/s)^2 = 7.47J PE = mgh 7.47J = .534 (9.8) h divide both sides by 5.23 to get 1.428 as h. |
| Feb4-07, 02:27 PM | #9 |
Mentor
| Feb4-07, 02:30 PM | #10 |
im sorry, but im a bit confused..how do i find the PE if i was not given h? to get the total mechanical energy
| Feb4-07, 02:38 PM | #11 |
Mentor
Let's call the three positions of interest 1 (starting point), 2 (where it leaves the track), and 3 (where it lands). How does the PE change when going from positions 1 to 2 to 3?
You found the KE at position 2. Now add the PE at position 2 to get the total energy (which is the same at all positions). Measure PE from the ground level. (You were given h--it's on the diagram!) |
| Feb4-07, 02:38 PM | #12 |
gal m confuse with this problem too....
| Feb4-07, 02:40 PM | #13 |
aikenfan did u find PE for point 1
| Feb4-07, 02:42 PM | #14 |
so for PE at point 2 it would be :
PE = mgh = .534(9.8)(2.4) =12.56 ? |
| Feb4-07, 02:46 PM | #16 |
the total energy would therefore be 20.02
which would make: 20.02 = 1/2 (.534)(v)^2 divide both sides by .267 and get 74.98...take the square root to get 8.65m/s? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Block on frictionless ramp
| A mass and a frictionless ramp | Introductory Physics Homework | 3 | ||
| Block sliding down frictionless ramp while being pulled with constant force? | Introductory Physics Homework | 9 | ||
| Block going up a frictionless incline | Introductory Physics Homework | 1 | ||
| Box on a frictionless ramp. | Introductory Physics Homework | 8 | ||
| How far does a block go up a frictionless ramp? | Introductory Physics Homework | 2 | ||
