Finding the Best Prop Setup for Bowfishing Boats
  • Thread starter Thread starter justinduke
The discussion focuses on optimizing propeller setups for bowfishing boats, specifically using a 24hp Honda horizontal shaft engine with a 4-blade 48" propeller at 8 degrees pitch. Users are encouraged to consider switching to a 3-blade propeller with increased pitch for enhanced thrust. Additionally, the concept of a 'ducted fan' is introduced as a method to improve performance by enclosing the propeller in a tube made of plastic or sheet metal. Participants are advised to explore existing threads on propeller configurations for further insights.
  • Understanding of propeller mechanics and thrust generation
  • Familiarity with Honda 24hp horizontal shaft engine specifications
  • Knowledge of propeller pitch and blade count effects
  • Experience with ducted fan design principles
  • Research the performance differences between 3-blade and 4-blade propellers
  • Investigate the impact of propeller pitch on thrust and efficiency
  • Learn about ducted fan designs and their benefits for shallow water navigation
  • Explore user experiences and recommendations on bowfishing boat modifications
Bowfishing enthusiasts, boat builders, and marine engineers looking to enhance the performance of shallow water boats through optimized propeller setups.
justinduke
Hi everybody I'm new to the site and figured you all could help me out. I have a boat that I use for bowfishing and on the back I have a swivel setup with a 24hp Honda horizontal shaft engine turning a 4-blade 48" prop at 8 degrees(have to double check that). Anyways the prop, or fan as I call it, is used to push the boat through very shallow water. How would I go about finding the best prop setup for me that would create the most thrust? What I need to know is if say a 3-blade prop with more pitch would perform better for me? Any help would be appreciated. Here is a link to a video of a boat similar to mine just so you can get the idea of what I am talking about.
http://www.arbowfishingboatfab.com/videos/arbowfishingboatmod1.wmv
There are a couple of other threads around here dealing with props, so you might find what you want by just reading through the last week or so of Engineering posts. One thing that will help, even with your current equipment, is to enshroud the prop in a plastic or sheet-metal tube to create what is known as a 'ducted fan'.
Ok thanks. Yeah I put sheet metal around the outer ring of the shroud when I first built it.
10K
  • · Replies 20 ·
11K
