Thread Closed
Sliding rod on wall
Share Thread Thread Tools
Feb8-07, 05:11 AM   #1
Recognitions:
Gold Membership Gold Member
Sliding rod on wall
Here's a question (not homework) that someone asked me a few days ago:
you have a rod with length L and mass M that's leaning against a frictionless wall and makes a 30deg angle with the floor. what does the static friction have to be inorder for the stick to stay inequilibrium?
What i did was to pretend that all the mass was at the center of the rod. then i split the force mg on that point into two parts - "along the rod" and perpendicular to the rod. the force along the rod pushes the bottom of the rod into the ground with and angle of 30 bellow the ground. the perp force induces a normal force which also has two parts - along the rod and perp to the rod going up. this perp force creates a torque which also pushes the bottom of the stick into the ground.
So basically i summed up all these forces and got the answer:
Ustatic >= 0.6sqrt(3)
But the real answer is
Ustatuc >= 0.5sqrt(3)
What it the correct way to deal with this problem?
Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb8-07, 08:09 AM   #2
Mentor
Whether "homework" or not, all textbook/coursework-type questions should be posted in the appropriate "Homework Help" section. I'll move it.
I can't really follow what you are doing here. To solve this, just consider all the forces acting on the ladder:
(1) Gravity, which acts down through the center of mass (you started off with that)
(2) The force from the wall--since there's no friction, it acts horizontally
(3) The force from the floor--break it into two components: friction force (horizontal) and normal force (vertical)
Now just apply the conditions for translational and rotational equilibrium.
Feb8-07, 03:20 PM   #3
Recognitions:
thanks, i got it now.
Thread Closed
Thread Tools
Similar Threads for: Sliding rod on wall
Thread Forum Replies
Can't walk through a wall. Quantum Physics 30
sliding ice Introductory Physics Homework 4
Get into the wall !!! Atomic, Solid State, Comp. Physics 2
thick wall or thin wall ? Biology 3
block sliding on vertical wall Introductory Physics Homework 1
