What will be the current in the resistence after 5 minutes?
  • Context: High School
  • Thread starter Thread starter athenaroa
    Value
The discussion centers on a scenario where a 10V potential difference is applied across a resistance, resulting in a current of 0.2 amps. The resistance value is confirmed to be 50 ohms. After maintaining this voltage for 5 minutes, the current in the resistance remains constant at 0.2 amps, as temperature is not a factor affecting the current in this context. This establishes that under steady conditions, the current does not change over time.
  • Understanding of Ohm's Law
  • Basic knowledge of electrical circuits
  • Familiarity with the concept of resistance
  • Knowledge of current measurement in amperes
  • Study Ohm's Law and its applications in electrical circuits
  • Explore the effects of temperature on resistance in conductors
  • Learn about real vs. ideal resistors in circuit analysis
  • Investigate the implications of constant voltage on current flow over time
Electrical engineering students, hobbyists working with circuits, and professionals involved in circuit design and analysis will benefit from this discussion.
athenaroa
At exactly 1:00 pm on a certain day a 10 v potential difference is suddenly applied across a 'real' resistance and generates a current of 0.2 amps in the resistance. The value of the resistance at this moment is about 50 ohms. Let's say the 10 v are held constant and current is allowed to travel through the resistance for 5 minutes. At the end of the 5 minutes, the current in the 'real' resistance is expected to be what? this is not a trick question, temp is not a factor.
0.2 amps
Is temp constant?
What are you getting at? Is this a trick question or a genuine enquiry?
  • · Replies 105 ·
14K
19K
  • · Replies 0 ·
  • · Replies 24 ·
9K
  • · Replies 16 ·
