What are the Units and Instruments for Measuring Magnetic Fields?
Magnetic fields are quantified using the units of Teslas and Gauss, with 1 Tesla equating to 10,000 Gauss. Permanent magnets derive their magnetism from the alignment of magnetic domains, which can be measured using instruments such as Hall effect probes and flip-coil magnetometers. The strength of a permanent magnet's field is typically assessed at its surface. Additionally, the magnetic field intensity can be calculated using the formula F_m = IBl, where I represents the current in the wire, B denotes the magnetic field intensity, and F_m is the force on the wire.
  • Understanding of magnetic field concepts
  • Familiarity with measurement units: Teslas and Gauss
  • Knowledge of Hall effect probes and magnetometers
  • Basic physics principles, particularly electromagnetism
  • Research the operation and applications of Hall effect probes
  • Study the principles of flip-coil magnetometers
  • Explore advanced calculations of magnetic fields using Ampère's Law
  • Learn about the properties and applications of permanent magnets in various industries
Students in physics, engineers working with magnetic systems, and researchers interested in magnetic field measurement techniques will benefit from this discussion.
Jonh Doe
I would like to know what is(are) the unit(s) of measurement for the magnetic fields of permanent magnets, and what is the instruments for measuring it (if one exists). Thirdly, is there a way to calculate such a field (mathemeticaly, by measurements, etc...)
I have heard of many things (ampere-meters, volt-tour, etc...), but I can't seem to be able to see clearly in all of them.
Thank you for your answers
Magnetic Fields
Magnetic fields are measured in terms Teslas and Gauss. 1 Tesla = 10000 Gauss. Permanent magnets get their magnetism from the alignment of magnetic domains within the material of the permanent magnet. Each magnetic domain acts like a little bar magnet. Aligning all the little bar magnets within the material creates a strong magnet. Most permanent magnets are characterized by their field strength at the surface of the magnet. This is typically measured with a Hall effect probe or other magnetometer. One simple method is with a flip-coil magnetometer. Those are described in most every undergraduate physics textbook.
Good luck!
At class we measured the magnetic field B of a given magnet by measuring the force on a wire with current.
[tex]F_m = IBl[/tex]
When:
[tex]I = \mbox{ current in the wire }[/tex]
[tex]B = \mbox{ magnetic field intensity nearby the wire }[/tex]
[tex]F_m = \mbox{ length of the wire }[/tex]
  • · Replies 42 ·
  • · Replies 31 ·
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 27 ·
