| Thread Closed |
displacement |
Share Thread |
| Feb17-07, 04:05 PM | #1 |
displacement
Two sinusoidal waves travel in the same direction and have the same frequency. Thier amplitudes are Y1 and Y2. The smallest possible amplitude of the resultant wave is:
a) Y1+Y2 and occurs if they are 180 degrees out of phase b) [Y1-Y2] and occurs if they are 180 degrees out of phase c) Y1 + Y2 and occurs if they are in phase d) [y1-Y2] and occurs if they are in phase e) [Y1-Y2] and occurs if they are 90 out of phase. I think the answer would be A if Y1 +Y2 and they are 180 degrees out of phase. I choose the answer based on the fact that superposition is based on the Y1 +Y2= resultant. So if the waves were out of phase they would produce the smallest resultant because the other is the complete reverse of the other. I thinking deconstruction. Two identical waves but separate string, with the same tension carry sinusoidal waves with the same frequency. Wave A has an amplitude that is twice that of wave B and transmits energy at a rate that is _____ that of wave B. a) half b) twice c) one-fourth d) four times e) eight times iI thought the answer would be B because the amount of energy carried by a wave is related to the amplitude of the wave. A high energy wave is characterized by a high amplitude; a low energy wave is characterized by a low amplitude. The amplitude of a wave refers to the maximum amount of displacement of a a particle on the medium from its rest position. The energy imparted to a pulse will only effect the amplitude of that pulse. Help is appreciated 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Thread Closed |
Similar discussions for: displacement
| displacement | Introductory Physics Homework | 1 | ||
| Help with displacement | Introductory Physics Homework | 15 | ||
| Displacement | Introductory Physics Homework | 7 | ||
| Displacement | Introductory Physics Homework | 4 | ||
| displacement | Introductory Physics Homework | 2 | ||
