Make a Homemade Drum: Physics Basics for Beginners
  • Thread starter Thread starter BrainFreeze
    Physics
This discussion focuses on creating a homemade drum using materials like plastic and metal, specifically a trash can lid. The key physics concepts discussed include tension, resonance, and sound wave frequency, emphasizing that tighter drumheads produce higher-pitched sounds due to increased tension. The conversation also highlights the historical use of animal skin and the modern alternatives of metal and wood for drum construction. The participant successfully implemented these ideas in a classroom setting, demonstrating the practical application of the discussed physics principles.
  • Basic understanding of sound waves and frequency
  • Familiarity with the concept of tension in physics
  • Knowledge of materials suitable for drum construction
  • Awareness of historical drum-making techniques
  • Research the physics of sound waves and their properties
  • Explore different materials for drumheads and their acoustic properties
  • Learn about resonance and how it affects sound quality in musical instruments
  • Investigate the historical evolution of percussion instruments
This discussion is beneficial for students in physics, music enthusiasts interested in instrument construction, and educators looking for practical applications of physics concepts in real-world scenarios.
BrainFreeze
I'm really bad at physics... *sigh* so for HW I have to make a drum out of homemade things. I think I am going to use plastic to put over the drum part.. Is there any other mateial that would be better? And also i have to explain the physics part of the drum. Using words like tension etc.
Heeeeelp me outt pleaaaaaaaaase!
I don't know what level of physics you're in, but I'm going to guess that it's Conceptual. In that case, you probably won't have to get too specific with equations and explanatory information from a mathematical standpoint. Just think, (I know you can do it) what besides plastic or an actual drumhead would make a good drum sound? Originally, drums from ancient civilizations would use animal skin as the drum head, but since that probably isn't an option here, let's look at an easily avalible resource: metal. Have you ever heard the sound that an empty paint can or garbage can makes when hit by a stick or other rod of some kind? Depending on how much stuff is inside of the drum, you will get varying levels of resonation, or sharpness. If you have say, a small pillow inside of your drum, the sound will have more bass tones and will resonate less. Also, if you've ever heard steel drums before (originally from the Carribean/Jamaican region) you'll know that certain metals such as steel, tin, or thick aluminum can be bent using a hammer or other pounding tool so that they play melodies. This might be an option for you. Aside from metal, wood can work well for drums, and if all else fails, buy a drumhead from a music shop. You can really apply tension when using professional drumheads. The more tension or less flexible the drum head is, the higher the higher-pitched it will sound and vice versa. Just in case you need to know specifics about tension, it's worth mentioning that tension is a resistance force that acts against (Newton's third law) the force acting upon it with an equal and opposite strength. If you tighten a drumhead with x Newtons of force, the drum will pull back with -x Newtons of force. By playing the drum, you are able to hear how much tension is acting upon the head because the sound waves that it produces are a direct quality of the tension acting upon it. When a loose drum [low tension] is played, it has more flexibility and therefore sends sound waves of lower frequency out into the air when compared to a tight drum [high tension] that has less give to it (causing the drumhead to vibrate back and forth more times per second), sending out sound waves of a higher frequency. Hope that helps a little.
thanks!
wow thank you so much.. i decided to go with the metal and use trash can top. I had to play it in class and explain about it.. and it worked perfectly. Thanks.
  • · Replies 17 ·
15K
  • · Replies 25 ·
11K
