map7s
- 146
This is just a general question... when trying to solve for the current in each resistor in a parallel circuit, how do you go about setting it up? (I know that the equation V=IR comes in handy...)
The current in parallel circuits is the flow of electric charge through multiple paths in a circuit. It is measured in amperes (A) and is the same at every point in a parallel circuit.
The total current in a parallel circuit is calculated by adding up the individual currents in each branch of the circuit. This is because the current in a parallel circuit splits up and flows through each branch separately, before joining back together at the end.
No, the voltage does not affect the current in a parallel circuit. The current is determined by the resistance and the voltage in each branch, but the total voltage in a parallel circuit is the same across all branches.
If one branch is removed in a parallel circuit, the total current will decrease. This is because the total resistance in the circuit increases, resulting in a decrease in the total current flow.
The current in a parallel circuit is different from the current in a series circuit. In a series circuit, the current is the same at every point, whereas in a parallel circuit, the current splits up and flows through each branch separately, resulting in a different current in each branch.
