Can anyone help me solve a Non-Homogenous PDE for my assignment?
  • Thread starter Thread starter Pauly Man
    Pde
The discussion revolves around solving a non-homogeneous partial differential equation (PDE) related to heat conduction in cylindrical coordinates, specifically involving Bessel functions. The original poster seeks assistance in verifying their work and understanding the solution process for the time-dependent part of the equation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • The original poster outlines a multi-step approach using separation of variables, addressing boundary conditions, and expanding the non-homogeneous term as a Fourier series. They express uncertainty in solving for T(t) in the context of a first-order differential equation.
Participants are actively engaging with the original poster's steps, identifying potential typographical errors and clarifying the formulation of the PDE. Some participants have suggested corrections and provided feedback on the mathematical expressions used. The discussion reflects a collaborative effort to refine the solution process without reaching a definitive conclusion.
There are indications of possible typographical errors in the original problem statement, particularly regarding the form of Q(r,t), which some participants believe may simplify the solution process. The discussion also highlights the importance of initial and boundary conditions in determining the final solution.
Pauly Man
I have an assignment due at the end of the week, and I was wondering if someone could check my working for me, as I am prone to making errors. Also, in Step Five I am unsure how to solve for T(t), can anyone point me in the right direction?
∂u/∂t = (c/r)*(r(∂u/∂r)) + Q(r,t)
0 < r < a ; c > 0
u(0,t) is finite
u(a,t) = 0
u(r,0) = 0
Q(r,t) = qJ0((&mu;1r)/a)
Where &mu;1 is the first crossing of J0(x), which is a Bessel Function of the first kind of order zero, q is a constant.
Solve for u(r,t).
Step One-
Use separation of variables on the homogenous equation, (ie. Set Q(r,t) = 0):
u(r,t) = R(r)T(t)
&rArr; &part;u/&part;t = RT'
&rArr; &part;u/&part;r = R'T
&rArr; &part;2u/&part;r2 = R"T
&rArr; (1/c)*(T'/T) = (R"/R) + (1/r)*(R'/R) = -&lambda;
Step Two-
Solve for R(r) first:
r2R" + rR' + &lambda;r2R = 0
let &lambda; = k2
and &rho; = kr
&rArr; dR/r = (dR/d&rho;)*(d&rho;/dr) = k(dR/d&rho;)
&rArr; d2R/dr2 = k2(d2R/d&rho;2)
&rArr; &rho;2R"(&rho;) + &rho;R'(&rho;) + &rho;2R(&rho;) = 0
which is Bessels equation, with &nu; = 0.
&rArr; R(&rho;) = AJ0(&rho;) + BY0(&rho;)
&rArr; R(r) = AJ0(kr) + BY0(kr)
where Y(x) is a Bessel Function of the second kind.
Now Y(x) approaches infinity as x approaches zero, therefore if R(r) is to satisfy the first boundaryb condition;
u(0,t) finite;
then B must equal zero.
The second boundary condition is;
u(a,t) = R(a)T(t) = 0;
&rArr; R(a) = 0 and/or T(t) = 0
Now T(t) = 0 is a trivial solution, as this implies u(r,t) = 0. So we look at R(a) = 0;
&rArr; R(a) = AJ0(ka) = 0
A = 0 is another trivial solution, so we look at;
J0(ka) = 0
We define &mu;n to be the nth zero of J0, then
kn = &mu;n/a
Setting A = 1 we get;
&rArr; R(r) = J0((&mu;nr)/a)
Step Three-
Expand Q(r,t) as a Fourier series of Rn(r):
Let Q(r,t) = &sum; bn(t)Rn(r)
Use the orthogonality condition:
&int; rJ0(knr)J0(kmr)dr = 0 ; n &ne; m
&int; rJ0(knr)J0(kmr)dr = (a2/2)*J12(kma) ; n = m
&rArr; bm(t) = 0 ; m &ne; 1
&rArr; bm(t) = (2q/a2J12(&mu;m))*&int; rertJ02((&mu;1r)/a)dr ; m = 1
(So far so good, I think. I have a solution for R(r) with no unknowns, and have expanded Q(r,t) out in terms of the eigenfunctions R(r), and have "solved" for the coefficient bm).
Step Four-
Substitute the solution;
u(r,t) = &sum;Rn(r)Tn(t);
into the original PDE;
&sum;RnT'n = c&sum;(R"n + (1/r)R'n)Tn + &sum;bnRn
Now R' + (1/r)R' = -&lambda;R
&rArr; &sum;(T'n + c&lambdanTn)Rn = &sum;bnRn
Use the orthogonality condition for Rn to get;
&sum;T'n + c&lambdanTn = &sum;bn
&rArr; &sum;T'n + c&lambdanTn = 0 ; n &ne; 1
&rArr; &sum;T'n + c&lambdanTn = (2q/a2J12(&mu;m))*&int; rertJ02((&mu;1r)/a)dr ; n = 1
Step Five-
Now I have to solve for T(t) using the equations above. For n > 1 the solution is easy to find;
T'n + c&lambda;nTn = 0
&rArr; Tn(t) = Cncos((&radic;c)(&mu;n/a)) + Dnsin((&radic;c)(&mu;n/a))
For n = 1 the I am unsure how to find the solution. The DE to solve is given below, and I've never had to solve a DE like it before:
T1' + c&lambdanTn = (2q/a2J12(&mu;m))*&int; rertJ02((&mu;1r)/a)dr
I can find the homogenous solution, however I can't find the particular solution. HELP!
The final solution-
The final solution is:
u(r,t) = J0((&mu;0r)/a)[C0cos((&radic;c)(&mu;0/a)) + D0sin((&radic;c)(&mu;0/a))] + (2 to infinity)&sum;J0((&mu;nr)/a)[Cncos((&radic;c)(&mu;n/a)) + Dnsin((&radic;c)(&mu;n/a))] + J0((&mu;1r)/a)[(Particular Solution of T1(t))
Sit tight--I'm printing this out and taking it home.
Till tomorrow...
I realized last nite that I for some reason solved the equation for T(t) as a second order DE, when it is clearly a first order DE. So ignore the final solution and part of step five.
For n &ge; 1-
T(t) = e-(c&lambda;nt)
OK.
I had some trouble getting through your initial post because of what I am convinced are typos.
For instance, think that this:
Originally posted by Pauly Man
&part;u/&part;t = (c/r[/color])*(r(&part;u/&part;r)) + Q(r,t)
Should be this:
&part;u/&part;t=(c&part;/&part;r[/color])*(r(&part;u/&part;r))+Q(r,t)
At least, that would be consistent with what you write later.
Also this:
&rArr; dR/r[/color] = (dR/d&rho;)*(d&rho;/dr) = k(dR/d&rho;)
Should presumably be this:
&rArr; dR/dr[/color] = (dR/d&rho;)*(d&rho;/dr) = k(dR/d&rho;)
Also, I don't know what
&rArr;
is supposed to be. It shows up as a rectangle.
If I'm right about those typos, then you are OK through Steps 1 and 2. I am still checking Step 3.
Yep, there was a typo there. Although it should still be c/r, and not c:
&part;u/&part;t=((c/r)&part;/&part;r[/color])*(r(&part;u/&part;r))+Q(r,t)
Also this:
Yep, that is correct.
&rArr;
That is supposed to be a "implies" symbol, it doesn't seem to work on all broswers and OS's. Sorry.
Cool. :smile:
I think I've solved it!
I found out today that the reason I was having so much difficulty with the problem was that the assignment had a "typo". Q(r,t) is not given by:
Q(r,t) = qJ0((&mu;1r)/a)ert
But by:
Q(r,t) = qJ0((&mu;1r)/a)e&nu;[/color]t
This makes the problem a heck of a lot easier to solve.
Step one and step two remain unchanged, step three changes only with the final answer:
bm(t) = (qe&nu;tJ02(&mu;1))/(J02(&mu;m)) ; m =1
Step four reamins unchanged until the end result:
where T'n + ckn2Tn = bn(t) , where bn is given above.
Step five becomes:
Step Five-
For n &ge; 1-
Tn(t) = Dne-ckn2t
For n = 1-
Let &alpha; = ckn2
Let &beta; = q(J02(&mu;1)/J02(&mu;n))
then;
T'1 + &alpha;T1 = &beta;e&nu;t
The integrating factor is:
I.F- e&alpha;t
So;
e&alpha;tT1(t) - T1(0) = (&beta;/(&alpha; + &nu;))(e(&alpha; + &nu;)t - 1)
Now, Tn(0) = 0 from the initial condition. SO the above simplifies. Now we add the T(t)'s together:
Tn(t) = (&beta;/(&alpha; + &nu;))(e&nu;t - e-&alpha;t) + (2 to infinity)&sum;Dne-ckn2t
Now let's look at the initial condition to determine Dn-
Tn(0) = (&beta;/(&alpha; + &nu;))(1 - 1) + (2 to infinity)&sum;Dn = 0
Tn(0) = (2 to infinity)&sum;Dn = 0
So Dn = 0
Therefore Tn(t) is given by:
Tn(t) = T1(t) = (q(J02(&mu;1)/J02(&mu;1))
/(ckn2 + &nu;))(e&nu;t - e-ckn2t)
Which upon simplification becomes:
Tn(t) = T1(t) = (q/(ckn2 + &nu;))(e&nu;t - e-ckn2t)
Therefore the final solution is given by:
u(r,t) = &sum;Rn(r)Tn(t) = R1(r)T1(t)
u(r,t) = J0((&mu;1r)/a)(q/(c(&mu;1/a)2 + &nu;))(e&nu;t - e-c(&mu;1/a)2t)
This solution satifsies the boundary and initial conditions, and so I hopw that it is right.
sweet jesus!
I'll check it and get back to you tomorrow.
Thanx for all the help Tom, I really appreciate it.
Most of the class has the same result, so I'm crossing fingers. :smile:
Originally posted by Another God
sweet jesus!
LOL. Looks daunting I agree. :wink:
Looks good to me.
Thanx for all the help Tom.
  • · Replies 19 ·
