Uncovering the Shortest Wavelength of Be3+ Lines
  • Thread starter Thread starter MrDMD83
    Lines Wavelength
The shortest wavelength of the triply ionized beryllium (Be3+) line spectrum can be calculated using the Rydberg formula: 1/λ = Rz²(1/n₁² - 1/n₂²). In this case, the atomic number (Z) for beryllium is 4, and the shortest wavelength for the doubly ionized lithium (Li2+) is 1979.8 nm. By applying the Rydberg constant and the appropriate quantum numbers, one can derive the shortest wavelength for Be3+ in the same series.
  • Understanding of the Rydberg formula for spectral lines
  • Knowledge of atomic structure and quantum numbers
  • Familiarity with line spectra and ionization states
  • Basic principles of spectroscopy
  • Calculate the shortest wavelength for Be3+ using the Rydberg formula
  • Explore the differences in spectral lines between Li2+ and Be3+
  • Study the implications of ionization states on spectral emissions
  • Investigate the applications of spectroscopy in identifying elements
Students in physics and chemistry, particularly those studying atomic spectra, quantum mechanics, and spectroscopy techniques.
MrDMD83
Doubly ionized lithium Li2+ (Z = 3) and triply ionized beryllium Be3+ (Z = 4) each emit a line spectrum. For a certain series of lines in the lithium spectrum, the shortest wavelength is 1979.8 nm. For the same series of lines in the beryllium spectrum, what is the shortest wavelength?
none
Hehe... give it a shot man. Tell you what, the equation you need is:
[tex]\frac{1}{\lambda}=Rz^2(\frac{1}{n_1^2}-\frac{1}{n_2^2})[/tex]
where R is the rydberg constant, z is the atomic number, and n2 is the shell it jumps from to n1 (the final shell)
