Digital Signal Transmission on Buses: Why Analog Signals Aren't Preferred
  • Thread starter Thread starter Swapnil
    Digital Signals
The discussion centers around the preference for digital signals over analog signals in bus systems, exploring the reasons behind this choice, particularly in terms of signal integrity and crosstalk issues. The scope includes technical explanations and conceptual clarifications regarding signal transmission methods in electronic systems.
  • Technical explanation, Conceptual clarification, Debate/contested
  • Some participants propose that buses are primarily used for digital signals due to the ability to recover content despite noise from crosstalk, which is less effective for analog signals.
  • Others argue that crosstalk between multiple lines can significantly corrupt analog signals, making them less reliable for transmission over buses.
  • A participant questions how buses corrupt analog signals and whether shielding methods are effective in preventing this corruption.
  • Another participant explains that digital signal buses typically use parallel traces over a ground plane, and while measures can be taken to reduce crosstalk, it remains a significant issue.
Participants generally agree that crosstalk is a problem for analog signals on buses, but there is no consensus on the effectiveness of shielding methods or the extent to which these issues impact signal integrity.
Limitations include assumptions about the effectiveness of shielding methods and the specific conditions under which crosstalk occurs. The discussion does not resolve the technical details of analog signal corruption on buses.
Swapnil
Are busses mostly used to carry digital signals?
If yes, then why so? Why aren't buses a popular means of carrying an analog signals?
Computer science news on Phys.org
Crosstalk between the multiple lines would corrupt the analog signals enough to generally cause problems. With digital signals, you can still recover the content, even with some noise added in from crosstalk.
For analog signals, you will generally keep them isolated from each other with coax or some other shielding method.
How exatly do buses corrupt analog signals? Don't they have some kind of shielding?
A typical bus of digital signals will be parallel traces run over a ground plane (like the traces are on the outer layer of a multi-layer PC board, with the adjacent inner PCB layer being the ground plane). The closer the traces are to each other, the more crosstalk you get. You can reduce the crosstalk by spreading out the bus traces, by decreasing the distance to the inner ground plane layer, and by running ground "guard" traces between each of the bus lines. But you will still get plenty of crosstalk, even with those measures.
9K
  • · Replies 41 ·
11K
