How Long Does It Take to Move a 0.1kg Object with a Tiny Force?
  • Thread starter Thread starter Thrawn
    Time
The discussion revolves around calculating the time required to move a 0.1 kg object a distance of 0.1 m under the influence of a very small force of 0.0000000132944 N. The problem involves concepts from classical mechanics, particularly Newton's second law and kinematics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between force, mass, and acceleration, questioning how to apply Newton's second law. There are attempts to derive time from the given parameters, but confusion arises regarding the correct application of units and the nature of the force involved.
Some participants have provided guidance on using Newton's second law to find acceleration and have suggested that the gravitational force may not be constant due to its dependence on distance. Multiple interpretations of the problem setup are being explored, particularly regarding the nature of the forces and the assumptions made about the system.
There is a lack of information about the mass of the larger object that is exerting the gravitational force, which is critical for a complete analysis. Additionally, the assumption of constant force is being questioned in light of the inverse square law governing gravitational attraction.
Thrawn
What is the time required to move an object of .1kg a distance of .1m
with a force of .0000000132944 N ?
N = 1kg m/s^2
N = 1kg m/s^2
N = 1kg m/s^2
S^2 = 1kg m/ N
sqrt s^2 = sqrt 1kg m/ N
S = sqrt 1kg m/ N
S = sqrt .1 (.1)/0.000000000132944
S = sqrt .01/0.000000000132944
S = 877s
No, that is not correct. You have taken the units of a quantity and made an equation out of it. Are you trying to use Newton's second law? Write the actual equation out. What do you first need to find out about the object's motion if a force is acting on it?
What I need to do is calculate the time required for an object with a set mass to move a set distance, with a set force exerted upon it.
Newton's second law, F = ma, requires that I know a, acceleration, which is expressed in meters (or other measurement) per second squared. However, I do not know how many "second squared" it takes.
In the contezt of the problem: A mass of 100g is placed on a beam free to rotate. Ten cm away, a larger mass is placed. The gravitational force between the two masses is 0.000000000132944 N, found through previous calculations. The distance is 10 cm (.1m), and the mass of the object is 100g (.1kg). How long does it take the object, with the force being applied to it, to come into contact with the attractive mass?
But I don't think you can take gravitational force as a constant force, because of the 1/d^2. So as the object gets closer it will accelerate faster. Is it assumed these objects are point masses? I'm guessing there might be information you haven't shared since there is no mention of the mass of the larger object in any of your previous posts (how else did you find F?).
Perhaps I'm being too rigorous with this, or I'm not understanding something??
"I do not know how many "second squared" it takes."
I'm not sure what you're trying to do with that. Those are units, not variables in your equation. Use Newton's second law to find acceleration since you know the force acting on the object and the mass of the object. You express this acceleration in m/s^2. You can then go on to find the time by basic kinematics.
This is of course assuming a constant force on the object.
