Solving Momentum Problem With Perfectly Elastic Collisions
  • Context: Graduate
  • Thread starter Thread starter Ed Quanta
    Momentum
The discussion revolves around a physics problem involving two spheres in a perfectly elastic collision scenario. The problem specifically addresses the sequence of collisions that occur when a larger sphere strikes the ground and subsequently collides with a smaller sphere above it. Participants are exploring the implications of conservation laws and the appropriate frame of reference to use in their calculations.
  • One participant describes the setup of two spheres falling, with the larger sphere on the bottom and the smaller sphere above, questioning how to calculate the smaller sphere's velocity after the larger sphere hits the ground.
  • Another participant suggests that after the larger ball strikes the ground, it rebounds with equal but opposite velocity, which should be used in the subsequent collision with the smaller ball.
  • Some participants propose using conservation of momentum and energy to solve the problem, although there is uncertainty about how to apply these principles in the context of the collisions.
  • A participant expresses confusion about the implications of the momentum conservation equation and the relationship between the masses, questioning how to determine the final velocities after the collisions.
  • There is a reiteration of the need to consider both momentum and energy conservation, as one participant points out that only the momentum equation has been presented in a previous post.
Participants do not appear to reach a consensus on how to approach the problem, with multiple competing views on the application of conservation laws and the choice of reference frames. The discussion remains unresolved regarding the specifics of the final velocities after the collisions.
There are limitations in the discussion regarding the assumptions made about the reference frames and the treatment of the collisions. The participants have not fully resolved the mathematical steps necessary to determine the final velocities, and there are dependencies on definitions that have not been clarified.
Ed Quanta
Two spheres are perfectly vertically alligned and falling towards the ground. They are separated by a small distance. The bigger sphere is on the bottom, and both spheres are supposed to have the common velocity v just before they strike the ground. I have to calculate the velocity of the smaller sphere, after the bigger sphere hits the ground. All collisions are perfectly elastic, and I am told to solve this as a sequence of closely spaced impulsive collisions. Help or ideas anybody? I am not sure what the sequence of collisions I am calculating are. And I am also not sure how to use either the lab or center of mass frame of references since the lab frame supposes that the velocity of one of the masses is zero which is not true, and the center of mass frame assumes the total momentum is zero, and I am not convinced that this is true.
The larger ball strikes the ground first (collision 1) it then collides with the smaller ball (collision 2). The larger ball will rebound with equal but opposite velocity. Use that velocity in the second collison.
Simply use the momentum and energy conservation laws. Thats enough to solve the problem.
Ok, but I am having trouble with what is going on in the second collision. I understand that when the larger mass hits the ground it will rebound with equal but opposite velocity. The smaller mass is going to collide with this mass with an equal but opposite velocity. However, since its mass is smaller, the momentum of the larger mass will be greater, and the total momentum will equal v(m-M) where m is the smaller mass, and M is the larger mass. However, this total momentum is non zero so I cannot use the center of mass frame?
-Mv + mv=v(m-M)=v1fM +v2fm
How am I to know the final velocities from this information alone? I want to know v2f, so v2f=(v(m-M)-v1fM)/m. But how am I to know v1f? I understand that momentum and energy are conserved, but how do the velocities change after the collision. It seems to me that they would be the same. By the way, v2f is supposed to equal v(3M-m/M+m).
You say "I understand that momentum and energy are conserved" but you have written only the momentum equation. As tomkeus suggested, use momentum AND ENERGY conservation.
  • · Replies 30 ·
  • · Replies 35 ·
  • · Replies 30 ·
