Thread Closed
Variable Voltage Source
Share Thread Thread Tools
Feb27-07, 11:06 AM   #1
Question
As the voltage in the circuit shown below is increased (but not to the breakdown voltage), the capacitance
a. increases.
b. decreases.
c. does not change.
d. increases, decreases, or does not change, depending on the charge on the plates of the capacitor.
e. does none of these.
2. Relevant equations
C = Q/V or C = (epsilon_0*A)/(d)
3. The attempt at a solution
If the voltage increases at a specific rate, then the charge would also increase since Q and V are directly proportional and the ratio between the two is a constant. Therefore, the capacitance does not change????
Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Feb27-07, 11:25 AM   #2
The capacitance should remain the same as it is a function of geometry and the material between the plates.
C = (epsilon * A) /d
Thread Closed
Thread Tools
Similar Threads for: Variable Voltage Source
Thread Forum Replies
Source Voltage and Max Power Engineering, Comp Sci, & Technology Homework 5
AC Source/ Variable Resistance Introductory Physics Homework 8
CIRCUITS: Current Controlled Voltage source, Indep. Voltage source, Four resistors... Introductory Physics Homework 1
CIRCUIT ANALYSIS: Use superposition - 2 Current source, 1 Voltage source, 4 resistors Advanced Physics Homework 6
Voltage & Current source Electrical Engineering 16
