Thread Closed
Something like Ceramic
Share Thread Thread Tools
Mar7-04, 01:57 PM   #1
I need ceramic for a very large electrical project. The problem I have is weight. I would like to find a material with all the properties of ceramic (electrical isolation, temperature insulation, armourment, ability to design for any shape), but it needs to be a lot lighter.
I thought there might be some types of plactics or fiberglas that I could use, but I've no idea.
Price won't be a problem. The material is needed. Anyone with ideas?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Mar22-04, 04:37 AM   #2
Carbon Fiber
JMD
Mar22-04, 08:14 PM   #3
Last time I checked, CF was an electrical conductor not an insulator.
CF's got some great properties - some that exceed ceramic. But, insulation is my primary need. :)
Mar25-04, 01:45 PM   #4
Recognitions:
Aerogel if it can take the heat.
How about a glass microsphere filled ceramic? It might lose a little compressive strength along with its weight loss but should otherwise retain electrical and thermal properties.
What temperature range are we talking about? I believe some of the Ren plastics can handle injection molding stress and temps. They list a casting resin here that goes to 408F for a 264psi deflection test:
http://www.freemansupply.com/tables/renepoxycasting.htm
And here's a laminating resin that's listed as 460F:
http://www.freemansupply.com/tables/renepoxylam.htm
Cliff
Mar25-04, 02:24 PM   #5
Recognitions:
I remember testing the optical properties of some plastics that were supposed to have good thermal and mechanical properties. They were:
Lexan - reinforced with glass fibers
Ultem - as above
Acrylonitrile Butadiene Styrene
Polyetheretherketone
Duron
Some of them had deformation issues. They would deform long before melting.
Njorl
Apr1-04, 06:23 PM   #6
Recognitions:
Gold Membership Gold Member
Quote by Njorl
Ultem - as above
Duron
Njorl
Then perhaps a thermoset, rather than a thermoplastic polymer would be in order. Something like Bakelite?
Apr5-04, 01:40 PM   #7
Recognitions:
Bakelite is very useful, but very toxic when you machine it. Be careful. I used it for a device once. I was lucky, I just drew up what I wanted and told some pros to make it.
Njorl
Apr25-04, 05:09 PM   #8
Where can I find chemicals for Bakelite? From what I've searched, it seems to be somewhat like fiberglas? I haven't found any detailed information about it - links anyone?
Thread Closed
Thread Tools
Similar Threads for: Something like Ceramic
Thread Forum Replies
Ceramic ic engine General Engineering 18
Ceramic Gas Sensors Materials & Chemical Engineering 4
Ceramic Supercapacitors General Physics 1
books on ceramic materials Science Textbook Discussion 4
Ceramic density Atomic, Solid State, Comp. Physics 5
