Angular velocity uniform rod problem
The problem involves a turnstile made of four thin, uniform rods rotating about a vertical axle. A mud ball is thrown and sticks to one of the rods, and the task is to find the final angular velocity of the system using the conservation of angular momentum.
  • The original poster attempts to apply the conservation of angular momentum and calculate the moment of inertia of the turnstile. They express uncertainty about the next steps after establishing the initial equations.
  • Some participants question the definition of the moment of inertia for the mud ball and clarify that it should be treated as a point mass.
  • There is discussion about the correct expression for angular momentum before the mud ball makes contact, with some confusion about the role of the cosine function in the calculation.
Poutine
Hi all, recently joined and having abit of trouble with a problem (several actually but I managed to figure out how to get started on one of them).
In any case the problem says:
Four thin, uniform rods each of mass M and length d = .75 m, are rigidly connected to a vertical axle to form a turnstile. The turnstile rotates clockwise about the axle, which is attached to a floor, with initial angular velocity w = -2.0 rad/s. A mud ball of mass m = M/4 and inital speed vi = 15 m/s is thrown and sticks to the end of one rod at an angle 60 degrees. Find the final angular velocity of the ball-turnstile system.
Now I think I have to use the Conservation of Angular momentum. As such I need to find the inertia of the turnstile which I think turns out to be IT=(4/3)*M*d^2
I think the formula I'm going end up with will probably be
It * wf + Ib * wf = IT* wi + angular momentum of the ball before the contact
The thing is I don't know how to get further from here.
I don't have a table of rotational inertias for different shapes in front of me, so I won't comment on that until tomorrow, after I look it up.
But as for where you go after that, you're basically done. You will have something like:
Iiωi=Ifωf
You know everything except ωf
(Don't forget to treat the mudball as a point mass, so Imud=mr2.)
Okay you answered my main question which is what is Imud? But I don't understand why that is true. Why is it mr^2, I was thinking it might have been 2/5 mr^2 but it seems I was wrong but I don't understand why.
Just to be certain the angular momentum before contact would be (M/4)*v*d*cos 60 right?
They don't give you the radius of the ball of mud, so that tells you to treat it as a point (it must be very small compared to the length of the rods). The rotational inertia of a point is I=mr2.
No, the cos(60) has nothing to do with it, as that only has to do with the configuration the system is in when the mud does make contact. The angular momentum beforehand is Li=Iiωi.
  • · Replies 71 ·
  • · Replies 17 ·
  • · Replies 62 ·
14K
  • · Replies 18 ·
