Register to reply
Chem 2: # of pi bonds in a molecule
by CausativeAgent
Tags: bonds, chem, molecule
Share this thread:
CausativeAgent
#1
Feb28-07, 10:00 PM
P: 18
How many pi bonds are in the molecule C12H18?
2. Relevant equations
I have in my notes the formula (6nPi+2-total # of electrons)/2.
3. The attempt at a solution
Unfortunately I can't find an explination for this formula in the book and I don't remember what was shown in lecture. I do know that there are 66 valence electrons total in this molecule. I also understand the basic definitions of pi and sigma bonds.
Phys.Org News Partner Science news on Phys.org
What lit up the universe?
Sheepdogs use just two simple rules to round up large herds of sheep
Animals first flex their muscles
mrjeffy321
#2
Feb28-07, 10:09 PM
Sci Advisor
P: 882
As I remember it,
For every single bond, you have one “sigma” bond.
If you have a double bond, you have one “sigma” bond and one “pi” bond.
If you have a triple bond, you have 1 sigma bond and two pi bonds.
So to find the total number of pi bonds in the molecule, you need to identify the number of double and triple bonds in the molecule.
# of pi bonds = (# double bonds) + (2 * # of triple bonds)
It would help to draw out the structure with the appropriate bonds between the atoms.
CausativeAgent
#3
Mar1-07, 08:42 AM
P: 18
Thanks for the reply. But I'm almost positive there is a quicker way to do it using that formula. This would be one of many questions on a one hour test and drawing the lewis structure for something that big would take me forever. One thing to add for clarification is I think technically that formula is for the maximum number of pi bonds. Also, it is not 100% accurate and may be off by one or two.
chemisttree
#4
Mar1-07, 09:24 AM
Sci Advisor
HW Helper
PF Gold
chemisttree's Avatar
P: 3,724
The empirical formula (C12H18) doesn't have enough information to tell you that without making at least one assumption. That assumption would be that the compound contains either a known number of cyclic structures or no cyclic structures. For acyclic compounds, the empirical formula should be CnH2n+2. You can prove this to yourself by inspection (try ethane, propane, etc...).
So, for a C12 molecule, the hydrogens should equal to 2(12)+2=26. We have 18 and at least 2 hydrogens must be removed to form each pi bond or cyclic structure. For example C6H12 could be cyclohexane (no pi bonds) or hexene (any of 3 isomers with 1 pi bond). If we assume that the molecule is acyclic, C12H18 has 8 fewer hydrogens that would be predicted for a saturated compound and therefore has 4 pi bonds.
For the answer to the question regarding the maximum number of pi bonds, assume that the molecule is acyclic.
CausativeAgent
#5
Mar2-07, 07:55 PM
P: 18
I finally just decided to ask my teacher. Your method does yield the correct answer but it shows a greater depth of understanding than we're required to have at this point. It turns out that formula just means six multiplied by the number of atoms that can potentially form pi bonds plus two minus the total # of valence electrons, all divided by two. So for C12H18 it would be:
(6x12+2-66)/2 = 4
Register to reply
Related Discussions
Gen Chem vs Intro Chem Academic Guidance 1
Bond where electrons are being transferred? Biology, Chemistry & Other Homework 4
How could you tell whether or not a molecule *could* have pi bonds? Chemistry 4
Bonds? Where are the val. e-'s Chemistry 5
