Question concerning rotation etc
  • Thread starter Thread starter JamesL
    Rotation
The problem involves the angular speed of a wheel changing over time due to friction, described by an exponential decay equation. The original poster presents specific values for initial and final angular speeds and a time interval, seeking to determine the unknown constant and the angular acceleration at a given time.
  • Exploratory, Assumption checking
  • The original poster attempts to solve for the unknown constant and angular acceleration using the provided equation but expresses uncertainty about the initial speed value. Some participants suggest differentiating the angular speed to find angular acceleration.
The discussion includes attempts to calculate the unknowns based on the given equation, with some participants providing alternative approaches. The original poster acknowledges receiving help but does not elaborate on the resolution.
The original poster questions the validity of the initial speed provided in the problem statement, indicating potential confusion regarding the problem's instructions. There is also a hint in the problem suggesting the need to determine the initial speed, which adds to the uncertainty.
JamesL
Heres the question:
As a result of friction, the angular speed of a wheel changes with time according to the following equation :
angular speed = (initial speed)*e^(-phi*time)
where phi is some unknown constant.
The angular speed changes from an initial speed of 4.86 rad/s to 3.76 rad/s in 7.17 seconds.
Hint: use this information to determine the initial speed and phi.
Determine the magnitude of the angular acceleration after 2.19 seconds.
Heres how i tried to do it.
using the equation given, i said:
3.76 = 4.86*e^(-phi * 7.17)... and got phi = .035791
Then using the equation again, i got the angular speed after 2.19 s as 4.4936 rad/s.
So i tried to determine the magnitude of the acceleration by saying :
4.4936 = 4.86 + (angular accel)*(2.19)
and so getting .167306 as the angular acceleration...
However, my online homework submission site told me this was wrong. I am not sure where i went wrong. The only thing i can think of is that, possibly, 4.86 is not the right value for the initial velocity (only thought of this bc of the hint given in the problem.. It says to use the above info to find the initial speed, but it is given to you in plain english?)... but i don't really know..
Anybody want to try to help out?
You'd have more luck by simply differentiating the angular speed.
[tex]\frac{d\omega}{dt} = \alpha[/tex]
cookiemonster
cookiemonster
I appreciate the response... could you elaborate a bit on how to do that?
nevermind. i got it. thanks for the help again.
