Helicopter downwash force
by richwigmore
Tags: downwash, force, helicopter
richwigmore
richwigmore is offline
#1
Mar1-07, 10:49 AM
P: 1
Does anyone know how to calculate how much downwards force a helicopter would exert on the roof of a house if it hovered over it at 700ft?
Thanks
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
FredGarvin
FredGarvin is offline
#2
Mar1-07, 11:47 AM
Sci Advisor
FredGarvin's Avatar
P: 5,095
Depends, depends, depends.
There are way too many variables that need to be nailed down. Helicopter type. Gross weight. Altitude. Temperature.
Hoangthien
Hoangthien is offline
#3
Aug24-07, 05:05 AM
P: 3
assume that we have all the parameters, which theory will be used for the calculation?
FredGarvin
#4
Aug24-07, 06:44 AM
Sci Advisor
FredGarvin's Avatar
P: 5,095
Basic momentum theory in a hover which ties into Bernoulli would be the place to start. Essentially it is calculating the change in momentum of a column of air equivalent in area to the rotor disk.
http://www.public.iastate.edu/~aero442/unit2.pdf
ank_gl
ank_gl is offline
#5
Aug24-07, 11:03 AM
P: 733
apply bernoulli.
basically its the same problem as the old trick. would your truck go light if all the birds inside it took flight at the same time.
and 700 ft a lot of distance
Hoangthien
#6
Aug28-07, 01:16 AM
P: 3
Momentum theory is very good to calculate the induced velocity at rotor dics as well as at distance very below the rotor. Unforturnately, it does not have any information for determining the induced velocity at these points which are between the rotor dics and infinte distance, for example at 3 or 4 radiaus below the rotor.
FredGarvin
#7
Aug28-07, 06:14 AM
Sci Advisor
FredGarvin's Avatar
P: 5,095
Quote Quote by Hoangthien View Post
That is very true. Usually something along these lines would be calculated via fluid dynamics package or simply measured in the field. There are so many things that could have an effect on the outcome.
Register to reply
Related Discussions
Force on a helicopter Introductory Physics Homework 19
calculation of downwash of helicopter Mechanical Engineering 0
Helicopter downwash Mechanical Engineering 19
helicopter force question Introductory Physics Homework 8
