Thread Closed
An organic synthesis problem
Share Thread Thread Tools
Mar14-07, 07:06 AM   #18
Using NBS to create a low concentration of bromine is an accepted method of performing allylic substitution. But what is that first reaction? Grignard reagents reacting with acetylene? I've never seen it before. What is it called?
Molu
Mar15-07, 01:01 AM   #19
I dont know what the reaction is called, but grignards can react with a hydrogen on a sp hybridised carbon. It acts as a base for the acidic hydrogen.
Mar15-07, 01:06 AM   #20
Ouch. I made a mistake. When you would do that reaction, you would get methane, as the CH3 group would take away the hydrogen on the sp hyb carbon.
Mar16-07, 03:31 AM   #21
You could still over come that though. Instead of the gridnards thing, you could react it with CH3Cl in presence of NaOH, and proceed in the same way. That would give you your maelic acid in the end.
Mar17-07, 12:03 AM   #22
Other Sciences 2012
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by chaoseverlasting View Post
This would be an expensive way to make methanol...
Mar17-07, 05:03 AM   #23
How would you get methanol? The base would react with the acidic hydrogen and then CH3 would attack at that position giving you 2-butyne. That you would reduce using hydrogen gas in poisoned by lindlars catalyst. NBS to get Br at the allylic position and hydrolysis to get you the compound you require.
Mar18-07, 05:00 AM   #24
I don't think hydroxide is a sufficiently strong base to be able to extract the very weakly acidic acetylenic hydrogen. You need a much stronger base, like hydride or amide. On the other hand, it is a sufficiently strong nucleophile to displace chlorine from chloromethane in a SN2 attack, forming methanol.
Mar18-07, 08:49 AM   #25
No. Im sure of this reaction.
Mar19-07, 02:07 AM   #26
I strongly doubt it would work. Water is a significantly stronger acid than ethyne, therefore OH- (the conjugate base of water) will not be able to deprotonate ethyne to any significant extent. Consider this well known reaction: Adding Calcium Dicarbide (CaC2) to water results in protonation of dicarbide dianion to form ethyne. This indicates that the reaction
acetylene + OH- <-> acetylide + water
has a negligibly small equilibrium constant. Where did you find your reaction?
Molu
Mar19-07, 10:29 AM   #27
Other Sciences 2012
Recognitions:
Review some basic organic chemistry...
Organic halides in the presence of hydroxide ion. SN2 displacement leads to the replacement of halogen with hydroxyl. The product is an alcohol.
Do you think you can generate a carbanion of acetylene (pKa=25) with hydroxide? pKa of water is 14.
Thread Closed
Thread Tools
Similar Threads for: An organic synthesis problem
Thread Forum Replies
need help on organic synthesis Biology, Chemistry & Other Homework 2
Organic Chem - Synthesis of alcohols Biology, Chemistry & Other Homework 3
Organic Chemistry - Camphor Synthesis Biology, Chemistry & Other Homework 1
synthesis problem - help plss Chemistry 11
synthesis problem - chemistry Introductory Physics Homework 0
