| Thread Closed |
Parallel Wires |
Share Thread | Thread Tools |
| Mar5-07, 11:14 PM | #1 |
Parallel Wires
Two long parallel wires, each with a mass per unit length of 43 g/m, are supported in a horizontal plane by 6.0 cm long strings, as shown in Figure P19.64. Each wire carries the same current I, causing the wires to repel each other so that the angle between the supporting strings is 16°. Determine the magnitude of each current. 2. Relevant equations sin (theta) = opposite/hyp I^2 = [(2pi)(d)(mg/L)] / [(4pi)e-07] 3. The attempt at a solution First I found d (the distance between the wires). Which is 2[sin(8)](0.06m) = 0.0167m. Then I substitute the given into this equation: I^2 = [(2pi)(d)(mg/L)] / [(4pi)e-07]. I = sq.root of [(2pi)(0.0167)(0.043)(9.8)] / [(4pi)e-07]. the answer I got is 132.64 A. What did I do wrong? I tried using free body diagram. T = mg/sin8 Tcos8 = [(I^2)(L)((4pi)e-7)] / [(2pi)d] (mgcos8)/(sin8) = [(I^2)(L)((4pi)e-7)] / [(2pi)d] (mg/L)(7.115) = [(I^2)((4pi)e-7)] / [(2pi)0.0167] I = 159.8 A Still incorrect. |
| Mar5-07, 11:36 PM | #2 |
Ah shoot, I've made the most stupid mistake ever. I solved it.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Parallel Wires
| Magnetic forces between parallel wires | Introductory Physics Homework | 7 | ||
| force between two parallel wires | Introductory Physics Homework | 1 | ||
| Two Parallel Wires( in 2 hrs!) | Introductory Physics Homework | 14 | ||
| two wires in parallel and capacitence | Advanced Physics Homework | 1 | ||
| Parallel wires | Introductory Physics Homework | 9 | ||
