How Does the Ideal Gas Law Apply to a Cylinder's Thermodynamic Cycle?
  • Thread starter Thread starter Div
    Thermodynamics
The discussion focuses on the application of the Ideal Gas Law to a thermodynamic cycle involving a cylinder containing 2 moles of an ideal monatomic gas. Initially at state A with a volume of 1.0 x 10-2 m3 and a pressure of 4.0 x 105 Pa, the gas undergoes an isobaric process to state B, where the volume increases to 2.0 x 10-2 m3. The gas then transitions to state C at constant volume, maintaining the same temperature as state A. The pressure at state C is determined using the Ideal Gas Law, and the device is identified as a refrigerator due to the temperature and pressure relationships throughout the cycle.
  • Understanding of the Ideal Gas Law (PV=nRT)
  • Knowledge of thermodynamic processes (isobaric, isochoric, isothermal)
  • Familiarity with PV diagrams and their interpretation
  • Basic concepts of heat transfer and work in thermodynamics
  • Learn how to apply the Ideal Gas Law in various thermodynamic processes
  • Study the derivation and implications of the Carnot cycle
  • Explore the concept of heat engines versus refrigerators in thermodynamic cycles
  • Investigate the significance of work done by or on a gas in different processes
Students studying thermodynamics, physics enthusiasts, and professionals in engineering fields who require a solid understanding of gas laws and thermodynamic cycles.
Div
A cylinder contains 2 moles of an ideal monatomic gas that is initially at state A with a volume of 1.0 x 10^-2 m3 and a pressure of 4.0 x 10^5 Pa. The gas is brought isobarically to state B. where the volume is 2.0 x 10^-2 m3. The gas is then brought at constant volume to state C, where its temperature is the same as at state A. The gas is then brought isothermally back to state A.
a. Determine the pressure of the gas at state C.
b. State whether this device is a refrigerator or a heat engine. Justify your answer.
So here's my version of that,
n = 2mol
stateA
v = 1.0 x 10-2m3
p = 4.0 x 105 Pa
stateB
v = 2.0 x 10-2 m3
p = 4.0 x 105 Pa (Isobaric Process)
stateC
v = 2.0 x 10-2 m3 (Isochoric Process)
tc = ta
w = 0 (isochoric)
p = ?
p=F/A?
w=pdeltav?
a)i know that the fact tc = ta has something to do with this, but when i consider this i would get deltau to = 0 due to the isothermal process right? and if deltau = 0 then q=w then t=p.02? but then how would i solve for p if i don't know t? >_< this is confusing...
b)i know that if i made a pv graph for this id have something like A---->B then C directly under B but because i don't know the answer to question a i don't know exactly where, also does that even have anything to do with it? I am guessing that with less volume you have higher temperature and the opposite with lots of volume but then my teacher showed us that in carnot cycles its actually colder when there's less volume! i would have to say refrigerator just because at b; the only state where temperature changes it would increase becauseto maintain the same pressure at an increased volume you would have to have a higher temperature right?
help please? :(
Use the ideal gas law and do a PV diagram.
The path from A to B is a horizontal line to the right a distance of V0 (1.0 x 10^-2 m^3) . What happens to T from A to B? (use Ideal Gas Law). Is heat flowing? What direction (into or out of the gas?).
The path from B to C is a vertical line. What is the pressure at C? (use Ideal Gas Law). Is heat flowing? Direction?
For the path from C to A, T is constant so how does P vary with V? (use Ideal Gas Law). Is CA a straight line? Curve? Is heat flowing? Direction?
What does the area between inside the path represent? Is it positive or negative? (you have to add the areas under each path - careful with signs). Is work being done by the gas or is work being on the gas?
AM
