Differential equations - algebraic properties of solutions
The discussion revolves around demonstrating the linearity of the operator A defined by A[y](t) = ∫(s(y(s)) ds) from t to a. Participants are exploring the properties of linear operators in the context of differential equations.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Some participants attempt to apply integration by parts to the operator but express uncertainty about the limits of integration and the correct application of the method.
  • Others question the necessity of integrating and suggest focusing on the definition of a linear operator instead.
  • There is discussion about splitting the integral and how linearity applies to the operation.
  • One participant reflects on their understanding of the definition of linearity and how to demonstrate it without using integration by parts.
The conversation is ongoing, with various interpretations and approaches being explored. Some participants are beginning to clarify their understanding of linear operators, while others remain uncertain about how to proceed with the integration aspect as suggested by the hint.
Participants note confusion regarding the application of integration by parts in this context and express difficulties in understanding the problem requirements. There is a recognition of imposed homework rules that may limit their approaches.
braindead101
Show that the operator A defined by A[y](t) = integ(s(y(s))ds) [integration from t to a] is linear. (Hint: Use integration by parts.)
Attempt at the solution:
A[y](t) = integ(s(y(s))ds) [integ from t to a]
Using integration by parts:
Let u = s
du = ds
let dv = y(s)
v = 1/2 y^2(s)
so,
A[y](t) = s(1/2y^2(s)) - integ(ds 1/2y^2(s)) [i'm not sure how to change the integration limits]
A[y](t) = 1/2s y^2(s) - [1/2 (1/3 y^3(s))] (from ___ to ___)
and just sub in the integrating limits and simplify?
am i doing something wrong.
Well, firstly, what is the definition of a linear operator?
Does this mean s times the function y(s)? i.e. the integral [tex]\int_t^asy(s)ds[/tex].
Let u = s
du = ds
let dv = y(s)
v = 1/2 y^2(s)
y is a function, and so you can't integrate it like this! I would let dv=s ds and u=y(s). But then, I don't know the definition of a linear operator that you are using, and so do not know what you're trying to prove!
Let u = s
du = ds
let dv = y(s)
v = 1/2 y^2(s)
so,
What in the world are you doing? No one asked you to actually integrate!
A transformation, T, is linear if and only if T(ay1+ by2)= aT(y1)+ bT(y2).
What can you do with [itex]\int s(ay_1+ by_2)ds[/itex]?
i integrated since the hint was to use integration of parts
i have no idea what i am doing
i'm looking at the integral you posted hallsofivy
you can multiply the s in and split it into two integrals?
You can, since linearity is a property of intergals.
can i integrate it then?
or is that not the point.
im not quite sure what I'm doing, I've read the class notes. i don't really understand
anybody know what i can do
this is relaly causing me trouble
First go back and check the problem! If you are really to "Show that the operator A defined by A[y](t) = integ(s(y(s))ds) [integration from t to a] is linear" then do as Cristo suggested originally- check the definition of "linear" and show that it works here. I can not imagine how one would "use integration by parts" to do that.
definition of a linear operator means it must satisfy A[cy] = cA[y] and A[y1+y2]=A[y1] + A[y2]
i would probably know how to do this if it wasn't an integral and i had to show it is linear, but i really do not know where to start.
i think i have an idea how to do it now, without the integration by parts.. but my prof said that we are suppose to do it using that, i have no idea how.
but this is what I am doing right now (it seems right to me but correct me if I'm wrong):
A[y] = integ(s(y(s))ds)
A[cy] = integ(s(cy) ds)
A[cy] = c integ(s y(s) ds)
A[cy] = c A[y]
so i satisfied property 1
A[y1 + y2] = integ( s(y1+y2) ds)
A[y1 + y2] = integ( sy1 ds) + integ( sy2 ds)
A[y1 + y2] = A[y1] + A[y2]
so i satisfied property 2
so it is a linear operator?
but since i need integration by parts, I've no idea what to do.
