Hooke's Law, Force Constant Question
The discussion revolves around the relationship between the total force constant of two springs arranged in series and the individual force constants of each spring. Participants are exploring how the configuration of the springs affects their collective behavior when a mass is attached.
  • Participants are attempting to derive an equation relating the total force constant to the individual constants. Questions arise regarding the effects of tension and stretch in the springs when configured in series versus individually.
The discussion is active, with participants questioning each other's reasoning about the stretching behavior of the springs and the implications for the total force constant. Some guidance has been offered regarding the relationship between tension and stretch in the context of the two-spring system.
There are indications of confusion regarding the effects of mass on the tension and stretch of the springs, as well as the assumptions about how the springs behave when combined. Participants are encouraged to clarify these points further.
BayernBlues
-How does the total force constant of two springs hung linearly compare with the individual force constants of springs.
-Predict the equation that relates the total force constant, ktotal, to the individual force constants, k1 and k2, of two springs joined together linearly.
*It's asking this question when a mass is attached to the bottom of one spring and the springs are attached to each other.
Fx=kx (Hooke's Law)
The force constant for two springs hung linearly should be slightly less than the sum of the force constant of the individual springs when they were experimented on without another spring attached. This is because a weight such as 500 g will cause two springs attached together to stretch less than it will cause an individual spring to stretch. The x value for two springs when two springs are attached together will be more than the x value if one individual spring is stretched with a 500 g weight. This is because the force constant for two springs attached together will require more compression or stretch than if an individual spring were to be stretched.
Slightly less?
Do they stretch less? Or more?
So they stretch more?
Seems like you are all over the place. Think of it this way: The stretch of a spring depends on the tension it is required to exert.
If you hang a mass M from one spring, what's the tension? How much does it stretch?
Now hang that same mass from two springs strung together. What's the tension in each spring? So how much does each spring stretch? What's the total stretch? Use this line of thought to deduce the spring constant of the double spring.
The tension is less in each spring so it stretches less. Here's what I got for the spring constant:
2ktotalxtotal = k1x1 + k2x2
When I plugged values from the experiment into this, left side equaled right side. Does that prove the equation?
The tension is the same in each spring. But the total stretch of the two-spring system will be the sum of the stretches of each individual spring. Use that reasoning to find the effective spring constant of the system
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 35 ·
