Gaussian Surface Derivations
The discussion revolves around a problem involving a solid nonconducting sphere with a non-uniform charge distribution, specifically focusing on deriving the electric field inside the sphere based on the given charge density. The subject area includes concepts from electrostatics and Gaussian surfaces.
  • Participants attempt to derive the total charge and electric field using different methods, including integration and ratios. Some question the assumption of treating the charge density as constant, while others explore alternative approaches without integration.
The discussion is ongoing, with various attempts to derive the electric field and total charge. Some participants have provided hints and corrections regarding the integration process, while others express confusion about the expected form of the answer. There is no explicit consensus on the correct approach yet.
Participants are navigating the complexities of a non-uniform charge density and the implications for integration. There is a focus on ensuring that the calculations align with the problem's requirements, and some participants highlight the need for careful consideration of the charge density's dependence on radius.
nealh149
For the following Eo is epsillon zero
41. A solid nonconducting spere of radius R has a uniform charge distribution of volume charge density p = kr/R where k is constant and r is the distance from the center. Show the (a) the total charge on the sphere is Q = pikR^3. (I did this, it's fine) and (b) that
E = (1/(4piEo)(Q0R^4)(r^2) gives the magnitude of the electric field inside the sphere.
41. For 41 (b) I tried to set up an integral. I new that Q = pV
Thus: Q = (kr/R)(4/3)(pi)(r^2) = [4kr^3(pi)}/[3R]
Because the gaussian surface is spherically symmetric
E = Q/(Eo*A) E = {[4kr^3(pi)}/[3R]} / (Eo*(4(pi)r^2)
This reduces to (kr)/(3EoR)
My proof seems to work alright, but it's not what the book asks you to find.
To find the charge, you need to integrate p dV. What you did was treat p as a constant--it's not constant, it's a function of r.
I tried to do it a totally different way, without any integration.
We know because density is a funciton of r we can set up a ratio.
Total Charge / Total Volume = Enclosed Charge / Enclosed Volume
Total Charge * Enclosed Volume / Total Volume = Enclosed Charge
So (pikR^3)(4pir^2) / (4piR^2) Q enclosed = [pi][k][r^3]
So put this into the Electric Field Formula
EA = Q/Eo So E = Q/AEo So E = ([pi][k][r^3])/(4pir^2)/Eo
So E = kr/4Eo
This seems logically correct, but not what there looking for. Can somebody give me some hints on how to do this correctly?
You must integrate!
This would be true if the charge density were constant, but it's not.
Instead, integrate:
[tex]Q = \int \rho dV = \int \frac{kr}{R} 4 \pi r^2 dr[/tex]
[tex]Q = \int \rho dV = \int \frac{kr}{R} 4 \pi r^2 dr = \frac{kr}\int{R}4 \pi r^2[/tex]
Thus Q = (4kpiR^3)/3 plugged into the gauss formula from before you get kR/3Eo
Still not working. I'm really having trouble
Redo that integral to get Q. I wrote it so you can see where each term originates--to do the actual integration, combine the r factors.
Ok I got (kr^2)/(4REo) Still Different.
To put the answer in the form they want, eliminate k. Use the formula you derived for total Q (in your first post).
  • · Replies 17 ·
  • · Replies 35 ·
