Register to reply
What does UFO mean?
by Newbie says Hi
Tags: None
Share this thread:
Newbie says Hi
#1
Mar2-07, 09:35 AM
P: 43
Quote Quote by Ivan Seeking View Post
That's not the definition. Are you saying than any unidentified object ever seen is a flying saucer?
You're right, it's not the definition. But to a lot of people (I don't know the stats here but based on my experience) "U.F.O" is not an acronym where one examines each of the 3 letters seperately and literally, but instead, is a word used to connote an object in the sky that invokes highly advanced technology beyond terrestrial explanation. I suppose, we could even say that to many people, the "U" in "UFO" means "unexplainable flying object." So based on this explanation (not that it is formal or saying you necessarily must accept it), I can see why one might mistake/interchange the word "UFO" for out-of-this-world-object (or flying "saucer" if you wish).
And no, certainly not any unidentified object ever seen is a flying saucer. Sometimes the "UFO" label is applied to meteors, sometimes the planet Venus -- neither one of which is "flying" so I think the label "UFO" fails and cannot be taken literally.
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
Ivan Seeking
#2
Mar2-07, 11:20 PM
Emeritus
Sci Advisor
PF Gold
Ivan Seeking's Avatar
P: 12,501
Quote Quote by Newbie says Hi View Post
Then obviously there are a lot of people who don't know what they're talking about. Since there are many well documented observations that lack specific explanations, unless you can prove that all atmospheric and other potentially observable phenomena have been identified, there is no justification for the assumption that all UFOs can be identified as known phenomena. But beyond that, if you go to the UFO Napster, you will see that U.F.O. is a term recognized by the United States Government, as well as by the military and intelligence communities.
I suggest also a review of the Credible Anomalies Napster
http://www.physicsforums.com/showthread.php?t=58374
If you wish to continue this, please start another thread.
russ_watters
#3
Mar9-07, 08:29 AM
Mentor
P: 22,303
We've had this discussion before, but I'd just like to point out the other two (well, 1.5) sides of that: there are some (how many would be an enlightening stat) flying saucer proponents who use the term UFO to mean (or at least imply) flying saucers. Some may be careless, some may be ignorant, and some certainly are dishonest. For a 'nobeliever', a judgement has to be made which they are dealing with.
And lets not forget: using the term "correctly" or not, the reason the discussion exists at all is because people are at least hoping that when the FO gets Id'd, it is positively shown to be a flying saucer. As I've pointed out before, if people were hoping to find new atmospheric phenomena (for example), they'd just call themselves meteorologists.
In any case, if you really want to be strict about the definition, you should probably consider the history and entemology. The term was coined during Project Blue Book as a replacement for 'flying saucers' (regardless of who actually coined it, it was coined for Project Blue Book, which had the specific purpose of evaluating their threat to national security). It is a better word, to be sure, but the implication that the term is referring to possible/suspected alien spacecraft dates to its origin and because of that, even those who seem like "respectable" ufologists often use the terms interchangeably. http://www.ufoevidence.org/documents/doc365.htm
Interchangeable usage of the term:
By any name, however, flying saucers and UFOs...
Characterization of the purpose of ufology via the questions it is to answer:
The phenomenon can and should be approched dispassionately and scientifically from a variety of angles, perceptual, psychological and sociological, to name but a few. If objects from another planet are indeed visiting ours, what form of propulsion system and other technologies are employed? What kinds of biological lifeforms might be onboard? What God or gods will they worship? And how will UFO occupants - now or in the future, immediate or remote - perceive humans: as mental, emotional and spiritual equals or as vastly subpar inferiors?
It is fitting though - an ambiguous term for an ambiguous pursuit.
The guy who wrote the article also understands me pretty well:
...a phenomenon that most skeptics routinely dismiss as non-existent by definition...
Well - by definition or by statistics. Assuming the stats weren't falsified for the purpose of a coverup, Project Blue Book judged 94% to be identifiable as non-flying saucers (I'm not sure about the level of certainty required for such a judgement) and judged 0% to be alien spacecraft. So since there were roughly 12,600 reports, a starting assumption that a new report is probably explainable has a 94% probability of being right (caveat: on this site, such reports are typically pre-filtered) and "not identifiable as a flying saucer" assumption has a 99.992% probability of being right. And that's the reason why such starting assumtions are reasonable - just as reasonable as a starting assumption that a new gravity experiment will produce results that conform to GR.
Ivan Seeking
#4
Mar9-07, 01:53 PM
Emeritus
Sci Advisor
PF Gold
P: 12,501
What does UFO mean?
Quote Quote by russ_watters View Post
In somes cases this may be true, but you have the chicken and the egg reversed. The implication of aliens evolved due to the nature of observed phenomena. IIRC, it was the USAF [Project Sign] that first mentions aliens as a possible explanation.
Also, some but not all observations clearly are atmospheric phenomena. Some might be cosmic phenomena for all I know [which, unlike you, I don't claim to]. UFOs are many things including ball lighthing and military aircraft. Historically, the greatest concern was that some UFOs were Russian/spy aircraft. This is why the CIA got involved.
You are aguing about popular usage. Well, many people will tell you that Einstein said that "everything is relative". So much for popular usage. Shall we take our lead from nitwits or the facts?
tehno
#5
Mar9-07, 02:13 PM
P: 363
UFO is an acronym for my vehicle.
Ivan Seeking
#6
Mar9-07, 02:52 PM
Emeritus
Sci Advisor
PF Gold
P: 12,501
Look at it this way, if we don't know how to explain an observation, we don't make assumptions about its nature. It's really very simple. Some people like Russ feel that they need to assume an explanation when we don't have one, so perhaps we need another name for this. We could call the field "assumptionology".
Ivan Seeking
#7
Mar10-07, 03:34 PM
Emeritus
Sci Advisor
PF Gold
P: 12,501
It has an official meaning. You all keep forgetting that UFO is an term used by the USAF and the aviation industry today, and that it means exactly what it says - unidentified. If we someday positively identify a UFO as an alien spacecraft, then it would be an IFO, not a UFO. You can muck it up all that you want, but even beyond the official recognition, the word "unidentified" is self-explantory.
In physics, the word and concept of "energy" has a specific meaning, but you will find other interpretations that have nothing to do with physics. To say that the definition in physics is somehow wrong because of popular usage, is silly, as is this discussion.
Register to reply
