Thread Closed
turbulent gas flow
Share Thread Thread Tools
Mar10-07, 10:23 AM   #1
turbulent gas flow
Hello
Im currently looking at turbulent gas flow in circular pipe sections by calculating the Reynolds the number. Does the Reynolds eqution hold for say flow of an ideal gas - air as it does for a real fluid say water.
This may sound like a stupid question and I supose I've got my head in a twist between the difference of a real fluid and a ideal gas, but I would like to know if I can calculate the reynolds number for a gas - in the same way I would say water through a pipe.
Any help would be greatly appreciated
A very confused Mancunian
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
>> Company pioneering new types of material for 3-D printer 'ink'
>> Student-built innovations to help improve and save lives
Mar10-07, 12:09 PM   #2
Admin
I expect Clausius2 to respond to the OP.
Meanwhile, Reynold's number can be used for gas flows.
http://www.grc.nasa.gov/WWW/BGH/reynolds.html
http://www.fas.org/sgp/othergov/doe/...s/00285906.pdf
http://www.owlnet.rice.edu/~jigarb/Reynolds_number.htm
Mar10-07, 03:36 PM   #3
Recognitions:
Reynolds number definition does not change due to fluid state that I have ever seen. The trick comes in, when dealing with gases, is getting accurate property values. An ideal gas is pretty easy, but it gets tricky when going away from the ideal model and you have to start correcting for pressure (compressibility) and temperature. At work, our aero guys have proprietary aero-thermo codes specifically for calculating properties that are non ideal in our engine decks.
Apr25-09, 08:05 PM   #4
turbulent gas flow
Quote by Mancunian View Post
A confused Mancunian
Hello Mancunian
don't be confused, Gases and fluids are measured equally in their way of getting turbulent or remaining laminar... That is hydrodynamics, yet remarcs of non ideal gases (electrically?) or ideal fluids (non -Stokes) remain of consequence.
greetings Janm
May16-09, 05:48 PM   #5
Hello turbulence freaks
You have to admit that yesterday waterballet is not only a olympic game anymore but entried entertainment. I know you want to hear here about turbulent gas flow, more difficult to see (coloured gasses?) then turbulent water (still remaining best drawing of L. daVinci) yet hanging water bassins brought to the public in Russia as an experiment for multimedia...
I was astounded...
And for calculating reynolds number for gasses: The Reynolds number is a dimensionless number. The way I was tought about that is: you can make a model with the same Reynolds number with very varied number of dimensions but if the Reynolds number is the same you get the transition of laminar to turbulent or the other way around in the same way as a model which uses the whole North Sea saying Norway has won...
Sorry for eventually poetic changes, but I am still impressed of the ESC...
greetings Janm
Thread Closed
Thread Tools
Similar Threads for: turbulent gas flow
Thread Forum Replies
Turbulent cells General Astronomy 2
taphonomy and turbulent flow dynamics General Physics 2
Laminar and turbulent flow Mechanical Engineering 10
Fully developed turbulent flow over a single plate Mechanical Engineering 0
Streamline or turbulent flow? Introductory Physics Homework 2
