Does the Gravitational Field Have Mass?
The discussion centers around the question of whether a gravitational field possesses mass, drawing comparisons to the mass associated with magnetic fields. Participants explore definitions of mass, the nature of gravitational fields, and the implications of energy localization in general relativity.
  • One participant suggests that since magnetic fields can be associated with mass, gravitational fields might also possess mass.
  • Another participant argues that mass is a defined concept with various interpretations, and questions the validity of equating gravitational fields with mass.
  • A request for peer-reviewed references is made to support claims about magnetic fields having mass, highlighting the ambiguity of terms like "mass" and "gravitational field."
  • Concerns are raised about the localization of energy in gravitational fields, with references to general relativity indicating that it is challenging to assign a definite value of energy density to gravitational fields.
  • Discussion includes the concept of ADM mass in general relativity, suggesting that gravitational binding energy can affect the mass of a system, complicating the relationship between mass and gravitational fields.
Participants express differing views on the relationship between gravitational fields and mass, with no consensus reached on whether gravitational fields can be said to have mass.
Participants note the ambiguity of the terms involved and the complexities of energy localization in general relativity, which may affect interpretations of mass in relation to gravitational fields.
magnetar
Gravitational field has mass?
As we all known:the magnetic field itself has mass(Electromagnetic Mass)for example,the neutron-star has strong magnetic field (10^8 tesla)! In per cube meter the magnetic field possesses about 44ton mass!(44000Kg according to E=MC^2)
So I want to ask:Gravitational field has mass too? thank you!
(I am a foreigner,my english is poor!)
Mass is a defined thing & there are many definitions of mass, but I've never heard this one before. I think its more accurate to say it doesn't follow the superposition principle. The field itself acts as a source of gravitons.
magnetar said:
As we all known:the magnetic field itself has mass.
How about a reference (ideally from a peer-reviewed source) for this "well known" fact, to help this topic get off to a good start.
Unfortunately, both the terms "mass" and "gravitational field" are somewhat ambiguous, even under ideal conditions. Given the fundamental ambiguity of these terms with the complicating fact that you are a non-English speaker, there is the strong potential for massive confusion here.
Thank you very much "pervect"!
The term:"mass"is the amount of material in an object (Kg)and the term "gravitational field "is a field (physics), generated by massive objects, that determines the magnitude and direction of gravitation experienced by other massive objects.
Unfortunately, it's not particularly clear if a magnetic field satisfies the definition of mass as a "quantity of material" that you offered.
You oferred this statement as "obvious", but never provided a source.
It's even less clear if the gravitational field contributes to "the quantity of material". That definition of mass is very vague, unfortunately.
I can say that it is impossible to localize the energy in the "gravitational field". See for instance http://en.wikipedia.org/wiki/Mass_in_general_relativity or the original source in Misner, Thorne, Wheeler, "Gravitation".
(The wikipedia source, which I should probably mention that I wrote, is not peer reviewed, only wikipedian reviewed, but the orignal source, MTW's "gravitation", is peer reviewed. Unfortunately, MTW isn't as accessible as the Wikipedia article).
Here's a quote from the Wiki article in question:
Unfortunately, energy conservation in general relativity turns out to be much less straightforward than it is in other theories of physics. In other classical theories, such as Newtonian gravity, electromagnetism, and hydrodynamics, it is possible to assign a definite value of energy density to fields. For instance, the energy density of an electric field E can be considered to be 1/2 ε0 E2.
This is not the case in general relativity. It turns out to be impossible in general to assign a definite location to "gravitational energy". (Misner et al, 1973 chapter 20 section 4).
If one adopts one of the usual defintions for mass in special relativity of
mass^2 = E^2 - p^2 (where E, p and m are in geometric units) or
mass^2 = (E^2 - (pc)^2) / c^2
our inability to localize the energy of the gravitational field is directly equivalent to saying that we can't localize the "mass" of the graviational field. (This is of course the so-called "invariant mass" of SR.)
Being unable to localize it does not mean, however, that gravitational binding energy does not affect the mass of a system.
For instance, if we assume that mass means, not "quantity of material", or even the "invariant mass" of SR, but rather "ADM mass" of GR, we can say the ADM mass of a pair of orbiting bodies that are close to each other (but well away from everything else, so that the system is isolated and the ADM mass concept is applicable) is not the same as the sum of the ADM masses of the same pair of bodies when they are separated and each body is an isolated system.
In the Newtonian limit, we can even say that the difference between the ADM mass of the system of two bodies and the sum of the ADM mass of each body "in isolation" is equal to the Newtonian gravitational binding energy of the system. (This is also mentioned in the Wiki article).
Thank you "pervect"!
You must be a good theoretical physicist!
  • · Replies 44 ·
  • · Replies 38 ·
  • · Replies 23 ·
