Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Geothermal Powerplants Share It Thread Tools Search this Thread image
Old Mar13-07, 11:34 PM                  #1
eaboujaoudeh
eaboujaoudeh is Offline:
Well most ppl thing this is a clean energy, but i'm skeptical about it. What we are doing here is that we are using the heat from the depth of the earth to cool our water for powerplants. If we build thousands of those to use this energy, wouldn't we be cooling our planet? cause otherwise those geothermal sources would be locked by thousands of tons of materials, but we are using fast cooling methods, u may say that its a small percentage and won't affect it! but thats what we used to say about polluting the earth and sea and oceans.....and a lof of other matters.
Old Mar14-07, 10:37 AM                  #2
russ_watters
PF Mentor
russ_watters is Offline:
It wouldn't be all that tough to calculate how much heat we'd be talking about...
Old Mar14-07, 10:47 AM                  #3
eaboujaoudeh
yeah but don't u think that it has a degrading effect on the earth's core?
Old Mar14-07, 03:39 PM       Last edited by edward; Mar14-07 at 04:00 PM..            #4
edward
edward's Avatar
edward is Offline:
Recognitions:
PF Contributor PF Contributor
Your thinking is on the right track, but the tremendous amount of heat contained by the earth and it's core would not significantly be affected by what we are capable of using.
We are limited on how deep we can go to utilize geothermal energy. What we use comes from much closer to the surface than to the core. Economically we are limited to using geothermal which already comes to, or very close to the surface.
The U.S. Department of energy even lists geothermal as a renewable energy source. Here are some good links on the topic.
http://geothermal.marin.org/geoenergy.html
http://wwwphys.murdoch.edu.au/rise/r.../geo/text.html
Old Mar15-07, 12:15 AM                  #5
eaboujaoudeh
well what i mean, was that when we used to throw garbage in the oceans, everyone used to say go ahead its a big ocean, now we found out that we were wrong, and its not a big ocean. We all know the conduction of water is large, so it has the ability to cool hot objects in a frightening speed.and in australia they are using a closed loop system to remove heat from the earth's core. We all know that eventually the earth's core is gonna cool by itself, we are making things worse by speeding that up.
Old Mar15-07, 01:20 AM                  #6
drankin
drankin is Offline:
Well, couldn't we use this approach to counteract Global Warming?
Old Mar15-07, 02:07 AM       Last edited by edward; Mar15-07 at 02:11 AM..            #7
edward
edward's Avatar
edward is Offline:
Recognitions:
Yep we did quite a number on polluting the oceans. Although a lot of that pollution came from polluted rivers running into the oceans, dumping dried sewage and hauling the garbage from cities out to sea , was definitely just plain stupid.
As far as ruining earths resources goes we have hopefully learned our lesson, although I sometimes question that at the rate we are polluting the atmosphere. If we use geothermal with forethought and caution we should be able to extract enormous amounts of energy without causing any significant changes in the temperature of the earths core. There is no current technical process for supplying all of our energy needs with geothermal.
There are a number of areas globally that use closed loop systems, but none of them that I know of actually extend down to the earth's core. Just ten miles down it is very hot. In a lot of areas, such as along the volcanic rifts of Iceland, the geothermal energy is practically at the surface. I doubt that it hurts anything to cool volcanic activity a bit, since most of this heat ends up being wasted anyway.
I don't really know the exact figures concerning how much energy over time could be extracted from the earth's core before it would start to cool, but I would hope that someone is taking this into consideration. Apparently you already have and that is a good sign.
BTW do you have a link to the closed loop system used in Australia?
Old Mar15-07, 12:51 PM       Last edited by russ_watters; Mar15-07 at 12:57 PM..            #8
russ_watters
PF Mentor
Earth's energy budget for geothermal is about 23 terawatts.
http://en.wikipedia.org/wiki/Earth's_energy_budget
Humans currently consume energy, from all sources, at a rate of about 3 terawatts (if I converted correctly...). http://energy.cr.usgs.gov/energy/stats_ctry/Stat1.html
So assuming we could suck all the energy we need out of the mantle, we'd cool the crust a touch, but we'd have virtually zero impact on the Earth's energy balance. All that heat would still be going to the atmosphere and at about the same rate and coming up from the core at about the same rate.
That said, with our limited technology, geothermal energy is only accessible if it is near the surface (ie, Iceland) in small pockets of magma and is therefore not technically renewable. Iceland will be ok for a while, though:
The government of Iceland states It should be stressed that the geothermal resource is not strictly renewable in the same sense as the hydro resource. It estimates that Iceland's geothermal energy could provide 1700 MW for over 100 years, compared to the current production of 140 MW.
http://en.wikipedia.org/wiki/Geothermal_power
Old Mar16-07, 02:23 AM                  #9
eaboujaoudeh
http://hotrock.anu.edu.au/ i think this website might be interesting.
As for me i watched it first on Discovery Channel, they passed on the subject briefly but caught my eye.
Old Mar18-07, 03:38 AM                  #10
devil-fire
devil-fire is Offline:
with geothermal energy there is a lot more energy being extracted per surface area then is exhausted naturally. instead of absorbing the surface energy, we would effectively be removing the insulation of the earths core and using the heat from the exposed core. the difference is vary small but its there.
humans have been dumping waste into rivers like they were a magical waste disposal utility for millions of years and only recently have we concluded we are having an impact. geothermal power plants speed up the cooling of the earth's core, but its like the impact humans had on the oceanic ecosystem tens of thousands of years ago. if we converted to geothermal energy, one day we would be thinking "damn our dependence on this energy source! by god its ruining our earth!" but until then we wouldn't be using coal, nuclear, oil, or hydroelectric energies.
its the same idea with cold fusion. if we got cold fusion going, we would forget about our energy wasting ways until we started to run out of ocean, then we would be really buggered! but hopefully by that time we would be able to suck the water off mars and shoot it back to earth
Old Mar18-07, 09:27 AM                  #11
Astronuc
PF Mentor
Astronuc's Avatar
Astronuc is Offline:
Russ nailed it.
The resource is limited to those areas near the surface. At the moment, the geothermal energy IS dumped directly into the environment - e.g. volcanos (and their associated geothermal zones) like St. Helens, Merapi, Ubinas, Tungurahua, Muana Loa and Mauna Kea, and Stromboli, to name a few.
http://en.wikipedia.org/wiki/Volcano
Many volcanos are associated with subduction zones at the intersections of tectonic plates, and those show no signs of slowing down.
The mid-Atlantic ridge is a great example of an area where the earth's geothermal energy is directly released into the oceans.
http://en.wikipedia.org/wiki/Mid-Atlantic_Ridge
http://en.wikipedia.org/wiki/Mid-ocean_ridge
http://en.wikipedia.org/wiki/Seafloor_spreading
The Wikipedia link cited by Russ shows the countries with significant geothermal programs. It makes sense in those areas where populations sit astride active geothermal areas.
Old Mar19-07, 01:40 AM                  #12
russ_watters
PF Mentor
It is quite easy to calculate the effects of both and see that the two are not at all analagous.
The supply of water on earth is so large it is impossible to calculate how many thousands or millions of years (it depends entirely on our growth projections) we could use it without depleting our oceans.
Old Mar19-07, 10:21 AM                  #13
drankin
drankin is Offline:
Any possibility that an increase geothermal activity could be contributing to the global warming cycle we are supposedly having?
Old Mar19-07, 10:35 PM                  #14
eaboujaoudeh
in my opinion our strive for power no matter what it is will cost the planet warming no matter were it comes from. for example if we take the sun's energy to use it on earth, we are using energy that otherwise might get reflected back to the universe we are trapping it inside our planet.
Old Mar20-07, 12:15 AM                  #15
russ_watters
PF Mentor
The sun imparts on the earth 174,000 terawatts of energy and we currently use, from all sources, 3. That's 1/1000th of a percent. I wouldn't be worried about humans having a significant direct impact on the Earth's energy balance.
The two things we can change are the greenhouse effect and earth's albedo.
image image
Reply
Thread Tools
Similar Threads for: Geothermal Powerplants
Thread Thread Starter Forum Replies Last Post
Geothermal energy wolram Earth 9 Dec5-08 11:01 PM
Geothermal Power Pythagorean Engineering Systems & Design 15 Jul1-08 01:56 AM
Geothermal civilization on Enceladus marcus Computing & Technology 0 May1-06 04:37 PM
Geothermal Well charachteristics anonymoose Mechanical Engineering 1 Mar4-06 12:03 AM
Offshore Geothermal Drilling Longstreet General Engineering 2 Dec21-05 10:06 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
