Current on 20 Ohm Resistor: Circuit Homework
  • Thread starter Thread starter jesuslovesu
    Circuit Current
The discussion focuses on calculating the current through a 20 Ohm resistor in a circuit involving two 10 Ohm resistors and a 5 Ohm resistor. The user initially applied Kirchhoff's Voltage Law incorrectly, leading to an erroneous current calculation of 0.45 A instead of the expected value. By simplifying the circuit and recognizing the series and parallel configurations, the user was guided to reduce the circuit to two loops, allowing for a more accurate analysis. The final resolution involved correctly applying the principles of circuit reduction and loop analysis.
  • Understanding of Ohm's Law
  • Familiarity with Kirchhoff's Voltage Law
  • Knowledge of series and parallel resistor combinations
  • Ability to solve simultaneous equations
  • Study circuit reduction techniques for complex circuits
  • Learn about Kirchhoff's Current Law
  • Practice solving circuit problems using mesh analysis
  • Explore the use of simulation tools like LTspice for circuit analysis
Students studying electrical engineering, hobbyists working on circuit design, and anyone looking to improve their skills in circuit analysis and problem-solving.
jesuslovesu
http://img65.imageshack.us/img65/4307/mymymyyw3.th.png
Find the current on the 20 ohm resistor.
Well, I'm fairly positive that the two 10 ohm resistors will transport the same amount of current so:
25V - I*25 - I2*10 = 0
25V + I3*5 - 10*I2 = 0
I = 2*I2 + I3
When I solve using those equations, I get I2 = 1.36 A and I = .45 A (I is double of what it should be).
Could anyone look at my equations and tell me what's wrong?
Reduce the circuit as much as possible. You put the 5 ohm and 20 ohm in series already. There is also the 5 ohm and 10 ohm that are in parallel. If you reduce that you will then have a circuit with two loops. Then you will only have two unknowns to deal with.
Ok, now I've got it, thanks
  • · Replies 18 ·
