Thread Closed
determine
Share Thread Thread Tools
Mar15-07, 08:48 PM   #1
determine
please help by explainig in steps thanx much
Determine if G and H are isomorphic. Justify your answer
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Mar16-07, 01:42 AM   #2
Mentor
You must show some work before we can help. One possible approach is to work out the degree of the vertices in each graph and try to identify those in G with those in H.
Mar16-07, 02:30 AM   #3
Quote by cristo View Post
hello
thanx i know about the dgrees but i still don't know how to determine that somtime the degree fo the vertices does tell you a bout that... so i know step by step details in order to know all possiblities.... i appreciate your help
thanx
Mar16-07, 04:00 AM   #4
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
determine
Very well, do you know what "isomorphic" MEANS? Notice that cristo did not just say "work out the degree" he also said "try to identify those in G with those in H". What have you done toward that? What is the degree of each point in G and each point in H?
Mar16-07, 05:41 PM   #5
okey thats what i have but i still need some one to explain that in steps
For G this graph is made of
a 3-cycle agc,
a 4-cycle hdbf.
For H this graph is made of
a 7-cycle 2583647. C
so G and H are not isomorphic
i am not sure if this iright or wrong and the same time i need some explanation so i can be sure for what i am doing
thanc
Mar16-07, 07:28 PM   #6
Mentor
You've not answered Halls' question: what does isomorphic mean? What is the degree of each vertex of G and each vertex of H?
Also, I don't understand your notation: what, for example, does the cycle agc mean? I would presume it to mean an edge from a to g, another from g to c and a third from c to a; but there is no edge from a to g in the graph G! Please explain your notation.
Mar16-07, 08:23 PM   #7
Isomorphic means same shaped,,,,,,,, now i need explanation
i tried to follow some examples with no luck
Mar16-07, 08:59 PM   #8
Mentor
Quote by hyderman View Post
You need to be more precise-- "same shaped" is not a mathematical definition of two isomorphic graphs.
Have you read the rest of my last post? Please answer my questions-- I will not tell you the answer without you putting some effort into solving the problem.
Mar16-07, 10:51 PM   #9
isomorphic:
Two graphs are isomorphic if there is a one-to-one correspondence between their vertices and there is an edge between two vertices of one graph if and only if there is an edge between the two corresponding vertices in the other graph.
G:
a-5 degrees
b-5
h- 5
for
H:
1-6 DEGREES
2-4
3-5
4-5
8-5 DEGREES
Thread Closed
Thread Tools
Similar Threads for: determine
Thread Forum Replies
Determine the frequencies Mechanical Engineering 0
Determine R value... Classical Physics 12
Determine M(x) Calculus & Beyond Homework 14
KCL / KVL to determine Vo Introductory Physics Homework 2
Determine whether f is even, odd, or neither? General Math 4
