| Thread Closed |
distorted event horizons and temperature of black holes |
Share Thread | Thread Tools |
| Mar20-07, 05:00 AM | #1 |
Black hole event horizons are circular in shape, in isolation.But if
one black hole approaches another black hole the event horizons of both holes must distort away from circular.Indeed the closer the holes get together the closer the distorted part of the event horizons between the holes must get to the centres of the black holes (because the gravity of one black hole can assist particles to escape from the other - if this were not true then we would have to say that one black hole has no gravity and therefore no mass -clearly ridiculous!). Some of the event horizon will be further away from the centre of the black holes because the gravity of one hole is helping the gravity of the other to keep particles from leaving it. So we would expect that overall the Hawking Radiation emitted for two Black holes approaching one another is the same as that for two distant "independent" black holes.However if we had one central black hole surrounded by thousands of others - all holes of equal mass - the event horizon of the central black hole would shift throughout its circumference towards its centre.Now, a black hole with a smaller scharzschild radius usually is a black hole with a smaller mass and a hotter temperature.So the central black hole would have a hotter temperature than expected.Is my logic here correct? |
| Mar21-07, 05:00 AM | #2 |
verdigris <verywellsaid@yahoo.co.uk> wrote:
> Black hole event horizons are circular in shape, in isolation.But if > one black hole approaches another black hole the event horizons of > both holes must distort away from circular. Right. In general, any matter outside the horizon can distort the shape. Visser calls such a distorted black hole a "dirty black hole." [...] > However if we had one central black > hole surrounded by thousands of others - all holes of equal mass - the > event horizon of the central black hole would shift throughout its > circumference towards its centre. Now, > a black hole with a smaller scharzschild radius usually is a black > hole with a smaller mass and a hotter temperature.So the central black > hole would have a hotter temperature than expected. Actually, you end up with a cooler black hole. You can find the details in Visser, "Dirty blackholes: Thermodynamics and horizon structure," Phys.Rev. D46 (1992) 2445, http://arxiv.org/abs/hep-th/9203057. He works out in detail, for instance, a black hole surrounded by a thin shell of matter. The piece you're missing, I think, is that the Hawking temperature of a black hole is the temperature as measured at infinity. (The temperature diverges at the horizon.) Photons emitted by a "dirty black hole" still have to get to infinity, and are red-shifted in the process by the field of the matter surrounding the black hole. It might be possible to ask about the temperature near the black hole -- inside the shell of matter distorting it -- to see how that is affected. This is a little tricky, though: you need to figure out what you mean by the "same position" in two different spacetimes. Perhaps you could look at the effect of slowly decreasing the radius of a surrounding shell of matter; this should be possible using section V.B of Visser's paper. Steve Carlip |
| Mar22-07, 05:00 AM | #3 |
carlip-nospam@physics.ucdavis.edu wrote:
> verdigris <verywellsaid@yahoo.co.uk> wrote: >> Black hole event horizons are circular in shape, in isolation.But if >> one black hole approaches another black hole the event horizons of >> both holes must distort away from circular. > Right. In general, any matter outside the horizon can distort the > shape. Visser calls such a distorted black hole a "dirty black > hole." > [...] >> However if we had one central black >> hole surrounded by thousands of others - all holes of equal mass - the >> event horizon of the central black hole would shift throughout its >> circumference towards its centre. I had replied earlier, but missed a key point. Start with Newtonian gravity. Consider a uniform shell of mass. What is the net gravitational force on an object inside the shell? The answer is that it's zero. This is obviously true at the exact center. It's less obvious elsewhere, but moving an object from the center towards the shell brings part of the shell closer, increasing attraction in that direction, while increasing the total mass in the opposite direction; it turns out that the two effects cancel. (You may be familiar with this is a different setting -- the electric field inside a uniformly charged shell is also zero.) It turns out that by Birkhoff's theorem, the same is true in general relativity. So if you have surrounded your central black hole by a uniform shell of other black holes, the net effect on it is zero. (Since your "shell" is not quite continuous, this won't be exactly true, but it's a good approximation.) The upshot is that the temperature of the black hole as measured inside the shell will be unchanged, while the temperature outside the shell will be decreased by the added red shift due to the mass of the shell. Steve Carlip |
| Thread Closed |
| Thread Tools | |
Similar Threads for: distorted event horizons and temperature of black holes
| Black Holes and the Event Horizon? | Special & General Relativity | 16 | ||
| Particle and event horizons | General Astronomy | 1 | ||
| [SOLVED] Two black holes and the event horizon.. | Astrophysics | 26 | ||
| The temperature of black holes | General Astronomy | 82 | ||
| The Quantization of Area (black hole event horizons) | General Astronomy | 0 | ||
