Gravitational potential energy-help
The discussion revolves around a physics problem related to gravitational potential energy, specifically involving the work required to lift coins stacked to a certain height and the potential energy stored in the stack. Participants are exploring the implications of the problem's parameters, including mass, gravitational acceleration, and height.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are attempting to derive equations for the work done in lifting the last coin and the gravitational potential energy of the entire pile. Questions are raised about how to accurately represent the height change for the last coin and whether to consider the potential energy of each individual coin or the entire stack.
The discussion is active, with participants providing insights and questioning each other's reasoning. Some guidance has been offered regarding the calculation of work and potential energy, but there is no explicit consensus on the correct approach or interpretation of the problem.
Participants are navigating the complexities of the problem, including the approximation required in the calculations and the significance of the height of the coins in relation to the overall setup. There is an acknowledgment of the need to consider the varying heights of the coins in the stack.
a seeker
hi, I came across a question in my physics textbook that I didn't get, so I was hoping that you guys could help me out a bit. :smile:
Here's the question. It's about gravitational potential energy, by the way.
** On your desk you have N identical coins, each with a mass m. You stack the coins into a vertical pile to height y.
a) Approximately how much work, in terms of m, g, and y, must you do on the last coin to raise it from the desk to the top of the pile?
b) Approximately how much gravitational potential energy, in terms of m, g, N, and y, is stored in the entire pile?
of course, we have the equation E_g=mg delta y.
I was thinking that for a), delta y would be something like y/N(N-1), y/N being the height of one of the coins. It's because you have to consider that the height of the coins should not include the one that you are raising from the desk. Is it right? and as for b), I have no clue. Can it be zero, or no?
Please help me!
Part a asks "approximately," you just need to consider how much work it takes to lift a mass up to the top of the stack.
Part b, each mass requires different amount of work since the final height changes, add the individual energies up.
well.. I am supposed to derive an equation for the situations using the variables given (like m, g, y, and N).
"Part a asks "approximately," you just need to consider how much work it takes to lift a mass up to the top of the stack."
-robb, i don't really understand what you are getting at. the work it takes to lift a mass up is indeed what I am asking, but how can you make an equation or a statement out of the variables?
and as for part b, why is there "a final height change"? can you be more specific? do we have to consider E_g of each coin, and not that of the whole pile (of coins)?
Well, you can get very technical for part a if you like and find the height of each coin since the n coins forms a stack of height y. Then the center of mass for the last coin is a distance y minus half the height of one coin. I do not think that is needed here though. You simply have a mass m that sits a height y above the zero of potential Gravitational PE of the top coin can be written in terms of these given quantities.
The second part is more interesting and involves a sum or integral, since the PE of each coin varies.
so you think gravitatial potential energy is simply E_g=mg delta y?
that's what i thought at first, but shouldn't we exclude the height of the coin that we are lifting up and make delta y= y/N(N-1)?
it's what I said at the beginning. *y/N=the height of one of the coins.
I understand your concerns.
As long as the thickness of one coin is much smaller than the total height we can ignore the fact that the top coin, when placed, has its center of gravity at a point below the position y above the table, as that position is to the top of the coin.
But in case your curious, I still do not think that you have the change in height of the last coin correctly.
Just as a check: your delta y for the last coin is much smaller than the value y itself. That doesn't seem correct, right?, it should be slightly less than the value y.
* again the question says approximately*
