| Thread Closed |
the set of ring automorphisms is an abstract group under composition |
Share Thread |
| Mar22-07, 11:46 AM | #1 |
Aut(R) denotes the set of ring automorphisms of a ring R Show formally that Aut(R) is a group under composition. 2. Relevant equations 3. The attempt at a solution I Have a very similar question to which I have the solution viz Aut(G) denotes the set of group automorphisms of a Group G, show that Aut(G) is a group under composition. Proof Let a,b: G -> G be automorphisms then [tex] a\circ b: G \rightarrow g is also an auto [/tex] [tex] (a\circ b)(xy) = a(b(xy))=a(b(x)b(y))= a(b(x))a(b(y)) [/tex] [tex] =(a\circ b)(x)(a\circ b)(y) [/tex] so [tex] a\circb [/tex] is a homomorphism it is also bijective since a,b are bijective [tex] \circ: aut(G)\times aut(G) \rightarrow aut(G) [/tex] is automatically associative (because comp of mappings is associative) As identity in Aut(G) [tex] take Id_g:G \rightarrow G [/tex] finally inverses Let a: G --> G be an auto then a^-1:G -->G is atleast a mapping and bijective need only show [tex] a^-1(xy) = a^-1(x)a^-1(y)[/tex] let [tex] x,y \in G [/tex] choose [tex] c,d \in G [/tex] : a(c)=x, a(d)=y [tex] a^-1(xy) = a^-1(a(c)a(d))=a^-1(a(cd)) = cd= a^-1(x)a^-1(y) [/tex] q.e.d .......the proof for rings is essentially the same right? The only thing that concerns me is the last part(above) since we used the fact that every element has it's inverse in a group but we don't have that in a ring....
| Mar22-07, 12:15 PM | #2 |
Recognitions:
Where have you used that fact?
| Mar22-07, 01:25 PM | #3 |
ok so i haven't and these two proofs are essentially the same?
| Mar22-07, 01:49 PM | #4 |
You did use a-1 where a is automorphism. You say you know
| Mar22-07, 03:46 PM | #5 |
no i've made a mistake it's supposed to be the group of isomorphisms
| Thread Closed |
Similar discussions for: the set of ring automorphisms is an abstract group under composition
| Abstract Algebra -- lifting up a factor group | Calculus & Beyond Homework | 1 | ||
| Abstract Algebra -- group | Calculus & Beyond Homework | 10 | ||
| Any right equivariant automorphisms that aren't group left actions? | Differential Geometry | 0 | ||
| Abstract Algebra group problem. | Calculus & Beyond Homework | 4 | ||
| abstract algebra proof: composition of mappings | Introductory Physics Homework | 1 | ||
