Forces involved in spring-pulley system
  • Thread starter Thread starter Luminous Blob
    Forces System
The discussion revolves around a spring-pulley system involving two equal masses, where the goal is to determine the equation of motion in terms of the spring's extension. The context includes considerations of forces acting on the system, specifically the tension in the strings and the gravitational force on the hanging mass.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to establish the equation of motion but expresses uncertainty about the coordinate system and the forces involved. Questions arise regarding the correctness of the tension equations and whether friction is a factor in the system.
Participants have engaged in clarifying the conditions of the problem, with some confirming the absence of friction. Guidance has been offered regarding the forces acting on the system, and there is a suggestion to consider the total mass affected by these forces. The discussion is ongoing, with no explicit consensus reached yet.
The problem is set in an idealized scenario without friction, which influences the analysis of forces and the resulting equations of motion.
Luminous Blob
I am trying to answer the following question:
Two equal masses are constrained by the spring-and-pulley system shown (the pulley has no mass and the surface is frictionless). Determine the equation of motion for the system in terms of x, the extension of the spring from its unstretched length. Solve for x as a function of time with the boundary conditions x = dx/dt = 0 at t = 0.
I have attached a word document with the diagram for the system. All that I've added to the diagram so far is T1, T2 and mg for the mass dangling over the edge.
Now, the last part of the question (solving for x with the boundary conditions) I can solve easily once I've actually figured out the equation of motion.
The problem I'm having is getting to the point where I have a second-order differential that I can solve. I'm not entirely sure how to choose my coordinate system (should I have an x and y coordinate system?) and I'm also not sure about the forces involved.
Are the tensions (T1 and T2) that I've drawn in correct, and what do they equal?
Is it just T1 = T2 = -kx + mg , or am I missing something?
I'd really appreciate it if someone can point me in the right direction here.
Your attachment didn't make it; try again.
Okay, hopefully it'll work this time...
Question: Is the mass on the table subject to friction, or are we working in super-perfect imaginary physics world?
cookiemonster
We're working in a super-perfect imaginary physics world :)
No friction forces involved.
Well, that makes life a bit easier!
We don't really need to consider tension, do we? All it's doing is communicating force between the blocks and the spring.
We got two forces, right? The restoring force of the spring and the force of gravity acting on the hanging block. So,
F = mg - kx
(I took gravitational force to be positive by assuming that the positive x direction was to the right, and you can see that gravity will always be pulling to the right)
And then we got
[tex]F = m_\textrm{total}\ddot{x}[/tex]
Now we have to address something. What mass are these forces acting upon, i.e. what is [itex]m_\textrm{total}[/itex]? The forces are trying to move both blocks, right? So [itex]m_\textrm{total}[/itex] should equal 2m. That leaves us with
[tex](2m)\ddot{x} = mg - kx[/tex]
which you'll need to solve.
Does that help?
cookiemonster
Originally posted by cookiemonster
Does that help?
cookiemonster
It certainly does. Thanks a lot!
  • · Replies 26 ·
  • · Replies 34 ·
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 18 ·
