Strange radioactivity question. fast
The discussion revolves around a problem related to radioactive emission ranges, specifically calculating detection rates for different source activities at various distances from a detector. The subject area is nuclear physics, focusing on concepts of radioactivity and particle detection.
  • The original poster attempts to find equations related to detection rates, distance, and source activity but expresses difficulty in locating relevant information. Some participants suggest reaching out to professors or tutors for guidance, while others emphasize the need for multiple equations to tackle the problem.
Participants are exploring various avenues for assistance, with some suggesting potential resources and others indicating the complexity of the problem. There is a recognition that multiple equations may be necessary, but no consensus on specific methods has been reached.
The original poster mentions having searched through major physics books and online resources without success, indicating a potential lack of accessible information on the topic. There is also an emphasis on not seeking direct solutions, but rather guidance on where to start.
EasyStyle4747
Strange radioactivity question. please help fast!
well, this is a strange question that i have to do a presentation on. I thought it would be easy but i can't find any information after looking through 2 major physics books and searching online. I even asked a tutor about this and still couldn't get any equations i could use. Plz don't bash me if this is the wrong forum. Just direct me to the right one then. This is the problem:
__________________________________
Radioactive Emission Ranges: For a 35 becquerel (Bq) source of alpha radiation, calculate the rate of particles arriving at a 5.0x10^-4m^2 detector located 20.0 cm, 50.0 cm, 100.0cm, and 130 cm from the source. Repeat the calculations for the same detector at the same positions for a 48 Bq source, a 125 Bq source, and a 1753 Bq source.
Tabulate and graph your results on a detection rate (Bq) versus distance (cm) graph, with source activity(Bq) as an extra parameter.
______________________________________
Just need an equation or equations to solve this. You don't have to solve it. I am not tryin to cheat, i just need to know where to even start with this thing. I can't find any equation that includes distance along with detection rate and area. Both books don't have anything. Am i suppose to use several equations together or wat? If anyone has any idea how this is done, please help me.
o btw, i just read the sticky warning, and i just want to be sure u ppl know that I am not telling you to solve this for me. I just need to know the equations involved and maybe some steps involved to solve this.
Hello there,
It seems like you are struggling with finding the right equations to solve this problem. I suggest reaching out to your physics professor or a tutor for more specific guidance on this topic. It's also a good idea to check online forums or websites dedicated to physics to see if there are any helpful resources or equations that can assist you with this problem.
In terms of finding the right forum, perhaps try posting in a physics or nuclear science-related forum to get more targeted responses from individuals who are knowledgeable in this area.
Additionally, don't be discouraged if you are having trouble finding the right equations or information. Sometimes complex problems like this require a bit more research and effort. Keep persevering and seeking help, and I am sure you will be able to solve this problem successfully. Best of luck!
Hello, it seems like you are struggling with your presentation on radioactive emission ranges. It can be frustrating when you can't find the information you need, but don't worry, I'm here to help. First of all, it's important to understand that there is no one equation that can solve this problem. You will need to use multiple equations and concepts to find the solution.
To start, you can use the equation R = A/d^2, where R is the detection rate in Bq, A is the source activity in Bq, and d is the distance from the source in meters. This equation gives you the detection rate at a specific distance for a given source activity.
Now, for the given problem, you will need to use this equation for each of the four distances (20cm, 50cm, 100cm, and 130cm) and for each of the four source activities (35 Bq, 48 Bq, 125 Bq, and 1753 Bq). This will give you a total of 16 calculations.
Once you have all the detection rates, you can create a table and a graph to visualize the data. The x-axis of the graph will be the distance in meters and the y-axis will be the detection rate in Bq. You can plot the data points for each source activity on the same graph and see how the detection rate changes with distance for each source.
I hope this helps you get started on your presentation. Remember, it's always a good idea to consult with your teacher or a tutor for additional guidance. Good luck!
