Statistics: Applications of sampling thoery
The discussion revolves around applications of sampling theory in statistics, specifically focusing on problems related to normal and triangular distributions. Participants explore calculations involving mean, variance, and probability, as well as the interpretation of distribution functions.
  • Homework-related
  • One participant presents a problem involving a cereal manufacturer's packaging weights, questioning how to calculate the percentage of boxes under a certain weight and the mean weight of selected boxes.
  • Another participant suggests that the notation "N(12.2, .04)" refers to a normal distribution with mean 12.2 and standard deviation 0.2, correcting the initial assumption of variance.
  • There is a discussion about the triangular probability density function (PDF) and its implications, with one participant suggesting it could relate to a binomial distribution.
  • Several participants propose integrating the distribution to find probabilities and means, while others express confusion about the formulas and concepts involved.
  • One participant provides a detailed calculation of expected value and variance for the triangular distribution, while another questions the relationship between integration and shortcut methods for finding these values.
  • There are references to using calculators and specific functions (like normalcdf) to assist in calculations, indicating a reliance on technology for solving statistical problems.
Participants express varying levels of understanding regarding the problems presented, with some agreeing on the need for integration and others disputing the necessity or correctness of certain methods. No consensus is reached on the best approach to solve the problems.
Participants note limitations in their knowledge of statistical tests and formulas, indicating that some concepts may not have been covered in their coursework. There is also uncertainty about the correct interpretation of the triangular PDF and its application to the problem at hand.
SparkimusPrime
I'm doing some homework over the break (!) so I don't have access to my usual lines of help. I've hit a wall:
A cereal manufacturer packages cereal in boxes that have 12-ounce label weight. Suppose that the actual distribution of weights is N(12.2, .04).
a) What percentage of the boxes have cereal weighing under 12 ounces?
b) if x-bar is the mean weight of the cereals in n = 4 boxes
selected at random, compute P(x-bar < 12).
I assume the "N(12.2, .04)" notation refers to that the distribution of the boxes has mean 12.2 and variance .04. I think 'a' has something to do with the normal distribution, how standard deviations mark percentages of the curve. 'b' I just have no clue on how to proceed.
Also:
Let W have the triangular PDF f(w) = 2w, 0 < w < 1.
What are the mean and variance of U = sqrt(18) * (W - 2/3)?
What do they mean by triangular?
The last portion of the class I would hazard a guess that I could integrate 'f(w)' to get the CDF 'W', but I'm not sure if that applies to this. The answer is supposed to be, 'mean = 0' and 'variance = 1' but damned if I can get it to come out that way just by manipulating the numbers.
A triangular pdf could indicate a binomial distribution (i.e. Pascal's Triangle). I'm not sure though.
I'd wager a guess that it just means the probability increases as w increases according to the line 2w. f(w) = 2w will give you a triangle, after all. Naturally, it still needs to be normalized, though.
N(12.2,.04) means a normal distribution with mean 12.2 and standard deviation (not variance) .04.
#1a) Integrate your distribution between 0 and 12.
#1b) Try using one of the tests you learned.
#2a) Okay.
#2b) You have formulas for this.
cookiemonster
Huh? I don't have a formula for this ditribution nor do I know how to make one.
Haven't learned any tests that look like that.
#2a) Okay.
Okay? I have formulas? Huh?
I'm going to email my teacher obviously I'm missing something.
I have checked the original question and it seems you are given the variance so you would calculate the z-score and use the z-table (you can search this on the interet I found http://itrs.scu.edu/psychology/faculty/turdan/stats%20ppts/chapter4.revision.tu.ppt with no trouble).
As for the "triangluar" you can get the answers by ignoring this term
"triangular" (If you shade in the area under the pdf it is a triangle but who cares).
the expected value of W is
[tex]E(W)=\int_0^1 w f(w) = \int_0^1 2w^2= 2/3[/tex]
the variance of W is
[tex](\int_0^1 w^2f(w) )- (E(W)^2) = (\int_0^1 2w^3) - (\frac{2^2}{3^2})= \frac{1}{18}[/tex]
you should now realize that you are close to the answer just use the formulas E(aW+b) = aE(W)+ b
and Var(aW+b) = a^2 Var(W)
Hint E(a(W-b)) = a E(W-b) = a ( E(W)-b))
subbing crap in gives
E( sqrt(18) (W-2/3) ) = sqrt18( E(W)-2/3) =0
cookiemonster -
1a)
The normal distribution:
http://mathworld.wolfram.com/NormalDistribution.html
Your calculator probably already does it for you, though. On a TI-83+, you'll use the normalcdf() function.
1b)
You haven't learned about t-tests?
2b)
Mean:
http://mathworld.wolfram.com/Mean.html
Variance:
http://mathworld.wolfram.com/Variance.html
I'm sorry, but those explanations do nothing for me. We haven't learned T-tests as far as I know.
Damned charming :) -
I have checked the original question and it seems you are given the variance so you would calculate the z-score and use the z-table (you can search this on the interet I found http://itrs.scu.edu/psychology/facu...revision.tu.ppt with no trouble).
I don't have power point, thanks though.
I can't get those pictures (?) to paste, but you get the idea. How did you do that anyway? That's kool.
Anyway, I got the first two answers correctly, those ideas go back several chapters, I have a firm grasp on those. But I'm not sure, exactly how they relate to part 'b'. I've tried doing the integrations the same way, but to no avail. The mean comes out correctly, to zero, but the variance is some strange number (sqrt(2)/6).
We've done this stuff, but shouldn't the integral come out to the same solution as the shortcut here?
[tex]\sqrt{2}/6 = \sqrt{ \frac{1}{18}}[/tex] which is the
standard deviation when the variance 1/18, as my integration confirms.
I am not sure what you mean when you say when the integration should be same as the short cut. An alternative method using integration is
[tex]E(W-2/3) = \int_0^1 ( W- 2/3)2W = 0[/tex]
PS if you want to know how I have done the integrals I have attached a txt file containing exactly what I typed.
