Have Scientists Discovered a 10th Planet in Our Solar System?
  • Context: High School
  • Thread starter Thread starter Grizzlycomet
    Planet
The discussion revolves around the potential discovery of a 10th planet in the solar system, specifically focusing on the object known as Sedna and its classification within the context of Kuiper Belt Objects (KBOs) and the Oort Cloud. Participants explore the implications of this discovery, the criteria for planetary classification, and the characteristics of Sedna compared to other celestial bodies.
  • Some participants mention that Sedna is larger than many other KBOs and may retain a tenuous atmosphere, similar to Pluto.
  • There is a suggestion that Sedna's discovery aligns with expectations of finding larger KBOs based on size distribution studies.
  • One participant argues that the existence of other planets beyond Pluto is unsurprising due to gravitational influences and advancements in detection methods.
  • Another participant expresses skepticism about the announcement, indicating that there are differing opinions on its significance.
  • Some discuss the classification of Sedna, with references to its perihelion distance and its potential relationship to the Oort Cloud.
  • There are references to historical context regarding Pluto's classification and how it may influence views on Sedna.
  • Questions are raised about the implications of Sedna's orbit and size for understanding the structure of the solar system.
Participants exhibit a mix of agreement and disagreement regarding the classification of Sedna and the implications of its discovery. While some view it as evidence of a larger population of celestial bodies, others remain skeptical about its significance and classification as a planet.
Participants note that the classification of celestial bodies can depend on definitions and criteria that may evolve over time. There are also unresolved questions about the nature of Sedna's orbit and its relationship to other known objects in the solar system.
Astronomy news on Phys.org
Cool. Thanks for the link, Grizzlycomet (nice username, BTW & welcome to Physics Forums!)
It will be interesting to see whether the IAU calls it a planet or not. Perhaps someday astronomers will find a Kuiper Belt Object larger than Pluto and then the debate will really heat up.
Seems like there are a lot of eyes on the Kuiper Belt lately. Other very recent KBO finds...
2004 DW = 1650 km (discovery announced last month)
Quaoar = 1250 km (discovered in 2002)
There seem to be a lot of "10th" planets.
Njorl
From http://www.ifa.hawaii.edu/faculty/jewitt/kb.html (excerpts only):
"Why is Sedna Interesting?[/color]
For at least two reasons:
1 It is larger than the other (roughly) 1000 KBOs discovered since 1992. Sedna is probably about 2000 km in diameter (Pluto is 2300 km). Scientifically, Sedna is most interesting because it might be large enough to retain a tenuous atmosphere, as does Pluto, at least at certain parts of its orbit when the temperatures are high enough for the gases to not be frozen.
2 Its distance from the Sun at discovery was greater than for any other KBO. This is not to say that other KBOs don't travel to larger distances than Sedna: they do. KBO 2000 OO67 travels out to 1000 AU (33 times the distance between the sun and Neptune), for example. It's just that these more extreme KBOs were discovered when closer to the Sun.
Is Sedna a Surprise?[/color]
No, it's an awesome thing to find, but it is not a surprise. This is because planetary astronomers have worked hard to measure the size distribution of KBOs and have expected for years to find objects of Pluto's size and perhaps a little larger. Sedna fits in with the measured size distributions.
Is Sedna a Planet?[/color]
Like Pluto, Sedna is most usefully regarded as a big Kuiper Belt Object. But if you think Pluto is a planet, you should probably label Sedna that way too, because it's almost as big. Get ready for a 20-Planet Solar System!"
There should be no surprise that there are other planets. Gravitation has no cutoff point, AFAWK. The only gravitational rival would be other stellar masses, and they are a light-year or more away. Traditional planets were known because they could be easily spotted. Even Uranus can be seen by sharp-eyed viewers who know where to look under excellent seeing conditions. Neptune is just a bit too far away for that and a telescope is needed. Pluto is too far away and too small, so you really need to know where to look. Other planet-like bodies farther out need luck to find them, but astronomers are always looking. Also, astronomers now have more resources for detecting presence of compact masses than previous astronomers had. The profound cold at significant trans-neptunian distances makes accretion into planetoid bodies likely. But proving they are planetary (around our sun) becomes more difficult with distance).
Hmmmm
======I myself am taking all this in slowly,======
=====and with a salt-shaker in each hand.======
This announcement is far more than it seems to be,
in my mind. I know others who agree with me, and
I know far more that strongly disagree with me.
Be advised - disclosure on the Ides of March...
Welcome to Physics Forums Human Being!
Would you like to explain your rather enigmatic first post?
Here's the http://www.spitzer.caltech.edu/Media/releases/ssc2004-05/release.shtml about Sedna.
The discoverers consider it to be evidence of the inner part of the Oort Cloud rather than Sedna being a Scattered Disk Object.
How does this relate to the Hubble findings last year, namely that the (classical) Edgeworth-Kuiper Belt seems to have an outer edge, at ~50 au? For example, might there be thousands of Sedna-like objects, which give rise to the outer edge of the EKB?
phht! that explains why my horoscope's always been wrong!
When Clyde Tombaugh discovered Pluto in around 1928, he classified Pluto as a planet, especially considering that he first thought that Pluto was the size of Earth (e had no idea of the Kuiper Belt back then either). But now we know better; and I do believe that Pluto really was just named a planet just because of incomplete facts. Pluto acts more like a Kuiper Belt object than a planet.
I *like it* when some of my musings turn out to have people like Jewitt say similar things . From the same Jewitt site as earlier, updated:
"Why is Sedna Interesting? [/color]
1 Its perihelion (closest approach to the Sun) is at 76 AU. This means that it is effectively beyond the scattering influence of Neptune. This is unlike the Classical KBOs, and unlike the Scattered KBOs. It is similar, dynamically, to 2000 CR105 (for which a/e/i = 227AU/0.805/22.7) which has perihelion at 44 AU, also outside Neptune's reach, and which has been discussed in papers by Gladman et al (Icarus 157, 269, 2002) and Emel'Yanenko et al (Monthly Notices RAS, 338, 443, 2003). Other objects have larger aphelia than Sedna's 990 AU (e.g. Kuiper Belt Object 2000 OO67, with aphelion at 1010 AU) and many comets travel to larger distances. Sedna is interesting because of its perihelion distance.
2 Sedna is large (1000 - 1500 km). An object this large cannot have formed by accretion in the tenuous regions of the protoplanetary disk corresponding to its current location. Sedna must have formed elsewhere, presumably amongst the planets or in the Kuiper Belt, and been ejected outwards. Lastly, its perihelion was lifted out of the range of Neptune. The orbit and the size attest to an early epoch in which strong gravitational scattering events rearranged the small bodies of the solar system.
Is Sedna an Oort Cloud Comet?[/color]
From the Classical Oort Cloud - no. The latter consists of objects whose orbits are so large (50,000 AU) that passing stars and galactic tides can alter their properties. Sedna doesn't travel very far out (1000 AU) and is effectively immune to external forces. Also, the inclinations of both Sedna and 2000 CR105 are small (12 and 23 degrees, respectively). These objects know where the plane of the solar system lies. Oort Cloud orbits are random with inclinations all the way up to 180 degrees.
So What Is It?[/color]
Sedna could be a member of a substantial population of bodies trapped between the Kuiper Belt and Oort Cloud. These would have been emplaced at early times and unseen until recently. 2000 CR105 and Sedna are "just the tip of the iceberg", as they say. The scientific interest lies in how these objects had their perihelia lifted out of the planetary region."
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 21 ·
