Elasticity in colloids (gels, jellies)
  • Thread starter Thread starter elaine216@hotmail.co
    Colloids Elasticity
The discussion revolves around the elasticity of colloids, specifically gelatine with varying concentrations of additives like salt and sugar. The original poster is utilizing ultrasonic testing to measure properties such as the attenuation coefficient and the speed of sound in the gelatine, which are related to the modulus of elasticity through specific equations. However, the challenge arises from the unknown density of the sample, complicating the calculations.
  • Exploratory, Assumption checking
  • Participants explore methods for calculating the density of the gelatine sample, suggesting direct measurement of mass and volume. There are discussions about the potential impact of additives on density and alternative equations that could relate sound velocity to elasticity without requiring density.
The discussion is active, with participants offering various suggestions for determining density and exploring different equations that might be applicable. There is an acknowledgment of the complexities involved in measuring elasticity due to the unknown density, and multiple approaches are being considered without reaching a consensus.
Participants note that factors such as temperature and concentration may influence the density of the colloid, which adds another layer of complexity to the experiments being discussed.
I have a question on finding elasticity of colloids.
I am using Ultrasonics testing on testing the different elasticity of gelatine with different concentrations of additives, ie, salt, sugar.
From the ultrasonics data, I calculated the attenuation coefficient and the velocity (speed of sound) of the gelatine.
there is an equation related to the modulus of elasticity:
V= sqrt (C/P)
where V is the speed of sound, C is the elastic constant and p is the density.
however, I don't know the denisty of the sample I tested. So, is there other ways to calcuate the density with the attenuation coef and velocity? or is there another formula that can solve my problem?
Please help...:(
It should be simple to calculate the density of your sample- I suspect that "additives" like salt, sugar, etc. won't noticably affect the average density so you might get away with just taking a sample of your gelatin, finding its volume and mass and dividing!
I would recommend making up a new batch with the additives and doing the same just to be sure that the density hasn't changed significantly.
Elasticity in colloids, such as gels and jellies, refers to the ability of these substances to deform under stress and return to their original shape when the stress is released. This property is important in many applications, such as in food and pharmaceutical industries.
In terms of finding the elasticity of colloids, such as gelatine with different concentrations of additives, ultrasonic testing is a commonly used method. This involves measuring the attenuation coefficient and velocity of the gelatine, and using an equation that relates these values to the modulus of elasticity.
However, in your specific case, you are facing the challenge of not knowing the density of the sample you tested. This can make it difficult to calculate the modulus of elasticity using the above equation. One possible solution is to use another equation that relates the velocity of sound to the density and bulk modulus, which can then be used to calculate the elastic constant. This equation is known as the Newton-Laplace equation and is given by:
V= sqrt [(K+4G/3)/ρ]
where V is the velocity of sound, K is the bulk modulus, G is the shear modulus, and ρ is the density.
Another option is to try and find the density of the sample through other means, such as using a densitometer or conducting density measurements using a pycnometer. This will allow you to use the original equation relating velocity, elastic constant, and density to calculate the modulus of elasticity.
In conclusion, there are alternative equations and methods that can be used to calculate the elasticity of colloids, such as gelatine, even when the density of the sample is unknown. It is important to carefully consider the specific properties and limitations of these equations and methods before using them to ensure accurate results.
Elasticity in colloids, such as gels and jellies, refers to their ability to resist deformation and return to their original shape after being stretched or compressed. This property is important in many applications, such as in food products, cosmetics, and pharmaceuticals.
In order to determine the elasticity of a colloid, testing methods such as ultrasonics can be used. This involves measuring the speed of sound and the attenuation coefficient (a measure of how much the sound waves are absorbed) of the colloid. These values can then be used to calculate the elastic constant, which is related to the modulus of elasticity.
However, in your specific case, you are facing a challenge in calculating the elasticity due to not knowing the density of the sample. While the equation V=sqrt(C/P) does require the density, there are other ways to determine the density using the ultrasonics data. One approach is to use the known density of the pure gelatine and then calculate the density of the gelatine with additives by measuring the change in attenuation coefficient and speed of sound.
Another option is to use a different formula that does not require the density, such as the Young's modulus equation, which relates the stress and strain of a material to its elasticity. This equation can be applied to your data to determine the elasticity of the gelatine with additives.
It is important to note that the density of a colloid can also be affected by factors such as temperature and concentration, so it is important to control for these variables in your experiments. Additionally, it may be helpful to consult with a specialist or conduct further research to find the most appropriate formula for your specific experiment.
In conclusion, while the density of a colloid is an important factor in determining its elasticity, there are alternative methods and equations that can be used to calculate this property. With careful consideration and further investigation, you should be able to determine the elasticity of your gelatine samples with additives.
  • · Replies 27 ·
