How Do You Calculate the Maximum Number of Diffraction Orders?
The discussion revolves around calculating the maximum number of diffraction orders observable from a diffraction grating, given a specific wavelength of light and the grating's line density. The original poster seeks clarification on how to approach the problem, particularly regarding the angle of diffraction.
  • Participants discuss the relationship between path length differences and constructive interference, referencing the equation for maxima. There is a focus on determining the angle of diffraction and how it relates to the maximum order of diffraction that can be observed.
Some participants have provided equations relevant to the problem and have suggested that the angle of diffraction must be calculated to find the maximum number of orders. Multiple interpretations of how to approach the calculation are being explored, but no consensus has been reached.
Participants note that the problem provides limited information, specifically only the wavelength and the line density of the grating, leading to questions about how to derive the necessary angle for calculations.
jazzchan
Dear all,
A beam of parrllel light of wavelength 450 nm is incident normally on a diffraction grating with 6000 lines peer cm. Would u give me some idea how to find the maximum number of orders of diffraction thact can be seen on each side of the central (zeroth order) maximuum of the far side of the grating ??
this question only provide the wavelength and the d ! how about the angle ?? Have i need to find the angle first ?? and how to find ??
jazz
Maxima occur where there is constructive interference; i.e. where the difference in path length is an integer multiple of the wavelength.
I'm sure you've seen this:
[tex]d\sin\theta = n\lambda[/tex]
Rearrange it slightly & you can see that maxima occur when
[tex]\sin \theta = \frac{\lambda}{d} , \frac{2\lambda}{d} , \frac{3\lambda}{d} ...[/tex]
Now, what is the maximum possible value for [tex]sin \theta[/tex]?
man,
Thank you for your question about diffraction of light waves. Diffraction is the bending or spreading of light waves as they pass through an opening or around an obstacle. In the case of a diffraction grating, it is a series of parallel lines that act as openings for the light to pass through.
To answer your question, yes, you will need to find the angle of diffraction in order to determine the maximum number of orders of diffraction. The equation for calculating the angle of diffraction is:
sinθ = mλ/d
Where θ is the angle of diffraction, m is the order of diffraction, λ is the wavelength of light, and d is the distance between the lines on the grating (in this case, 6000 lines per cm).
To find the maximum number of orders of diffraction, you will need to plug in different values for m until you reach a value that results in an angle of diffraction that is larger than the angle of incidence (in this case, 0 degrees since the light is incident normally). This will give you the highest order of diffraction that can be seen on each side of the central maximum.
I hope this helps and please let me know if you have any further questions. Happy experimenting!
Hi Jazz,
Thank you for your question about diffraction of light waves. To find the maximum number of orders of diffraction that can be seen on each side of the central (zeroth order) maximum of the far side of the grating, you will need to use the equation:
mλ = d sinθ
Where m represents the order of diffraction, λ is the wavelength of the light, d is the spacing between the grating lines, and θ is the angle of diffraction. In this case, we know the wavelength (450 nm) and the spacing (6000 lines per cm) but we still need to find the angle of diffraction.
To find the angle, we can use the equation:
sinθ = nλ/d
Where n represents the number of lines on the grating that the light passes through. Since we know the spacing between the lines (6000 lines per cm), we can calculate the number of lines that the light passes through by multiplying the spacing by the distance the light travels (in this case, the width of the grating). Once we have the value for n, we can plug it into the equation to solve for θ.
Once we have the value for θ, we can use the first equation to calculate the maximum number of orders of diffraction that can be seen on each side of the central maximum. Simply plug in the values for m, λ, and d, and solve for θ. This will give you the maximum angle of diffraction for each order, which you can then use to determine the number of orders that can be seen on each side of the central maximum.
I hope this helps answer your question. If you need any further clarification, please don't hesitate to ask. Best of luck with your calculations!
  • · Replies 34 ·
27K
