Finding RPM & Angular Velocity of a Wheel
The discussion revolves around calculating the rotations per minute (RPM) and angular velocity of a wheel based on its diameter and linear speed. The original poster seeks formulas to determine these values, given a wheel diameter of 26 inches and a speed of 20 feet per second.
  • Participants discuss various formulas for calculating RPM and angular velocity, with some suggesting conversions of units and others questioning the assumptions behind the formulas presented.
Multiple approaches to the problem have been shared, with participants offering different formulas and calculations. There is an ongoing exploration of unit conversions and the implications of using different values for diameter and speed.
Participants are navigating the conversion of units from feet per second to inches per minute and considering the impact of using different constants for pi in their calculations. There is also a focus on ensuring consistent units throughout the discussion.
celect
I can't find formula for determing the number of rotations a wheel makes in one minute.
Diameter = 26"
Traveling at 20 feet per second.
is there a formula for RPM?
Also need the formula to determine angular velocity.
thanks
Angular velocity W=V/R. You'll solve the given question after finding angular velocity
To determine the number of rotations per minute (RPM) of a wheel, you can use the following formula: RPM = (60 x speed) / (pi x diameter). In this case, the speed would be 20 feet per second and the diameter would be 26 inches. First, we need to convert the speed from feet per second to inches per minute, which can be done by multiplying by 60 (since there are 60 seconds in a minute). So the speed would be 20 x 60 = 1200 inches per minute. Then, plug in the values into the formula: RPM = (60 x 1200) / (pi x 26) = 138.46 rotations per minute.
To determine the angular velocity, you can use the formula: angular velocity = (2 x pi x RPM) / 60. In this case, the RPM would be 138.46, so the formula would be: angular velocity = (2 x pi x 138.46) / 60 = 14.51 radians per second. This formula calculates the angular velocity in radians per second, but you can convert it to degrees per second by multiplying by 180/pi.
I hope this helps you find the RPM and angular velocity of your wheel. Remember to always double check your units and make sure they are consistent throughout the calculation.
To find the RPM of a wheel, you can use the formula: RPM = (linear speed / circumference) x 60. In this case, the linear speed is 20 feet per second and the circumference can be found by multiplying the diameter (26 inches) by pi (3.14). So, the RPM would be (20 / (26 x 3.14)) x 60 = 45.9 RPM.
To find the angular velocity, you can use the formula: angular velocity = linear speed / radius. In this case, the linear speed is still 20 feet per second, but the radius would be half of the diameter (13 inches). So, the angular velocity would be 20 / 13 = 1.54 radians per second.
I hope this helps you in determining the rotations per minute and angular velocity of your wheel. Remember to always double check your units and convert if necessary to ensure accurate calculations. Best of luck!
  • · Replies 32 ·
  • · Replies 19 ·
  • · Replies 25 ·
