Second Order Op Amp circuit: Find Vo for t > 0
The discussion focuses on determining the output voltage \( V_o(t) \) for a second-order operational amplifier circuit with given parameters: \( V_{IN} = u(t) V \), \( R_1 = R_2 = 10 k\Omega \), and \( C_1 = C_2 = 100 \mu F \). The key equations derived include the KCL equations at nodes \( V_1 \) and \( V_2 \), leading to the expression for \( V_o \) as \( V_o = -R_2C_2\left(\frac{V_{IN} - V_1}{R_1C_2} - \frac{C_1}{C_2}\frac{dv_1}{dt}\right) \). The next step involves setting \( V_2 \) and \( \frac{dV_2}{dt} = 0 \) to simplify the solution process.
  • Understanding of operational amplifier circuits
  • Knowledge of Kirchhoff's Current Law (KCL)
  • Familiarity with capacitor current equations
  • Basic differential equations
  • Study the behavior of second-order systems in control theory
  • Learn about the Laplace transform for circuit analysis
  • Explore the impact of initial conditions on circuit response
  • Investigate the use of simulation tools like LTspice for circuit verification
Electrical engineering students, circuit designers, and anyone involved in analyzing operational amplifier circuits.
VinnyCee
In the circuit below, determine [itex]v_o(t)[/itex] for t > 0. Let [itex]V_{IN}\,=\,u(t)\,V[/itex], [itex]R_!\,=\,R_2\,=\,10\,k\Omega[/itex], [itex]C_1\,=\,C_2\,=\,100\,\muF[/itex].
http://img249.imageshack.us/img249/3840/problem867cg5.jpg
[tex]i_c\,=\,C\,\frac{dv_c}{dt}[/tex]
Add some node voltages:
http://img413.imageshack.us/img413/2935/problem867part2vn2.jpg
KCL @ [itex]V_1[/itex]:
[tex]\frac{V_{IN}\,-\,V_1}{R_1}\,=\,C_2\,\frac{dv_2}{dt}\,+\,C_1\,\frac{dv_1}{dt}[/tex]
KCL @ [itex]V_2[/itex]:
[tex]C_2\,\frac{dv_2}{dt}\,=\,\frac{V_2\,-\,V_o}{R_2}[/tex]
Substituting for [itex]\frac{dv_2}{dt}[/itex] in the KCL @ [itex]V_1[/itex] equation:
[tex]V_o\,=\,-R_2C_2\left(\frac{V_{IN}\,-\,V_1}{R_1C_2}\,-\,\frac{C_1}{C_2}\,\frac{dv_1}{dt}\right)[/tex]
Now what do I do to solve?
Set V2 and dV2/dt = 0. Does that help?
  • · Replies 36 ·
